765
Mirrors for official Cyanogen roms & OTA updates
  1. sandroziller
    Cupcake Sep 2, 2016
    sandroziller , Sep 2, 2016 :
    CARDIACS!!! BEST BAND EVER!
  2. Spannaa
    KitKat Sep 2, 2016
    Spannaa , Sep 2, 2016 :
    AGREED :cool:
    Its a fine man who cups his breath with a will to please...
  3. charandeep singh
    Cupcake Sep 5, 2016
    charandeep singh , Sep 5, 2016 :
    hey ,,,,,,i am currently on cm 13.1.1(OPO)......i want do degrade back to 11s(jio sim is not working in cm13).....can i flash 11s rom directly using twrp ????if no then give me some link/instructions.....thanks
  4. Spannaa
    KitKat Sep 5, 2016
    Spannaa , Sep 5, 2016 :
    A please would have been nice...
    Safest way to revert: Backup your internal storage and use a fastboot zip.
    Gonzo01 likes this.
  5. Gonzo01
    Lollipop Sep 5, 2016
    Gonzo01 , Sep 5, 2016 :
    that was an order. :D
  6. johncel.espares
    Froyo Sep 8, 2016
  7. charandeep singh
    Cupcake Sep 10, 2016
  8. daniga74
    Jelly Bean Sep 12, 2016
  9. Honkkis
    Cupcake Sep 12, 2016
  10. frederiksloth
    Eclair Sep 16, 2016
  11. SOMEJERKK
    Froyo Sep 16, 2016
    SOMEJERKK , Sep 16, 2016 :
    how is the standby time right now of cos 13.1.2...
    plus anyone using this rom with oxygen os firmware ..as my gps only works when i use oxygen os firmware .. but it breaks the proximity sensor ... i am on sultancm13 right now ... and i am having fc and gps bug ..
    so i am thinking about installing cos 13.1.2 ...
    and in my friends oneplus one ..cortana still doesnt work in India ... :/
  12. Little_Red_Devil
    Eclair Sep 19, 2016
    Little_Red_Devil , Sep 19, 2016 :
    Hi @SOMEJERKK
    I have the same problem.
    CM doesn't recognize this bug but there is a solution.
    I haven't tried it because didn't any spare time to do this.
    but read and try this: https://forums.oneplus.net/threads/how-to-fix-opo-compass-calibration-gps-issues-on-cm-cos.428796/
    I hope it helps.
    Cheers,
    L_R_D
  13. jack40k
    Cupcake Sep 19, 2016
    jack40k , Sep 19, 2016 :
    I'm trying to flash (via TWRP) cm-13.1.2-ZNH2KAS3P0-bacon-signed.zip over the top of 12.1-20151117-SNAPSHOT-YOG7DAO1K6-bacon but I'm getting the following error (see attached).
    I don't want to lose my data, root etc. Any way I can upgrade and keep them?
  14. SOMEJERKK
    Froyo Sep 19, 2016
    SOMEJERKK , Sep 19, 2016 :
    i have read that thread ... this deals with compass which actually works ,,in google maps ... but when i enter navigation .. it always says searching for gps .. and never gets a gps fix ..
  15. Spannaa
    KitKat Sep 19, 2016
    Spannaa , Sep 19, 2016 :
    No, the incompatible data line in your screenshot means you'll have to wipe data to install the new rom.
    Gonzo01 likes this.
  16. Little_Red_Devil
    Eclair Sep 20, 2016
    Little_Red_Devil , Sep 20, 2016 :
    What he says happens to his OPO it's happening to mine.
    The solution is for the compass but it also works for those issues, including the network signal breaks.
  17. sameer237
    Cupcake Sep 25, 2016
    sameer237 , Sep 25, 2016 :
    I want to upgrade my OPO to Android Marshmallow (currently running Oxygen OS 2.1.4). I've tried CM 13.0, but some of the enterprise apps I need to use check for root access and I was not able to use them. Is there any un-rooted MM ROM available for OPO?
  18. arjanvlek
    Honeycomb Sep 26, 2016
    arjanvlek , Sep 26, 2016 :
    The stock CyanogenOS ROM is not rooted and should work fine. You can download a copy from https://cyngn.com/support and install it using TWRP (I assume you have TWRP since you are on Oxygen). Choose the "normal" signed zip. Not the boot-debuggable or the fastboot one.
  19. paul.rym
    Gingerbread Sep 27, 2016
    paul.rym , Sep 27, 2016 :
    Hello everyone,
    I went back 20 pages, trying to find a definite answer for this, but didn't. Also checked the other thread with cm13 bugs, but, let's face it, all versions ave bugs, and they seem to be experienced differently by people.
    Therefore, can someone please help me and let me know which would be the best version (the one where you encountered the least amount of issues), after cm-13.0-ZNH0EAS2JK-bacon-signed-fastboot.zip ?
    I want to do a factory reset and update a little, so I was wondering if there is one in particular that was better than the others.
    Thanks!
  20. nickelodeon
    Honeycomb Sep 27, 2016
    nickelodeon , Sep 27, 2016 :
    I would recommend the last two updates
    cm-13.1.1-ZNH2KAS2X1 or cm-13.1.2-ZNH2KAS3P0
    preferable cm-13.1.2-ZNH2KAS3P0 because is the most recent with September security patch. I have zero issues with those two.
    paul.rym likes this.
