765
Mirrors for official Cyanogen roms & OTA updates
  1. Raikon_N
    Gingerbread Nov 12, 2014
    Raikon_N , Nov 12, 2014 :
    ^^ Thanks, yeah I'm using UniversalFlasher tool zip(which is also based from VRTheme). Will post the mod in new thread if I managed to do it successfully.
    /OT done
    #81
    Spannaa likes this.
  2. Spannaa
    KitKat Nov 19, 2014
    Spannaa , Nov 19, 2014 :
    Added cm-11.0-XNPH44S-bacon-signed-fastboot.zip & cm-11.0-XNPH44S-bacon-boot-debuggable.img to post #1
    #82
  3. jakehuitt1
    Donut Nov 19, 2014
    jakehuitt1 , Nov 19, 2014 :
    Will flashing one of the sgined flashable zips or unnoffical rooted zips will it wipe my phone? Will cyanogen recovery flash them? Also do I do the radio files after the rom or before?
    #83
  4. Spannaa
    KitKat Nov 19, 2014
    Neither will wipe the data on your phone as they don't touch the data partition.
    I always use TWRP recovery but the official signed flashable zips may be flashable in stock recovery.
    The signed flashable zips include the radio so, if you want to use a different one, flash it afterwards.
    #84
  5. Jan Vander Auwera
    Cupcake Nov 22, 2014
    Jan Vander Auwera , Nov 22, 2014 :
    Can someone help me to update my oneplusone?
    Currently my phone is running under cm version 11.0-XNPH22R.
    I tried two things:
    1) I have copied the file "cm-11.0-XNPH25R-bacon-signed-fastboot.zip" to my phone, booted in recovery and tried to apply this update, but that didn't work.
    2) My phone told me there was a system update(XNPH25R) ready, i tried the system update but that also didn't work.
    Can somebody help me?
    #85
  6. JuanL
    KitKat Nov 22, 2014
    #86
  7. areyesrn
    Ice Cream Sandwich Nov 22, 2014
    areyesrn , Nov 22, 2014 :
    you can't flash the fastboot.zips in recovery.
    go here...they updated it to 44s...I did it and everything's good...just, you know, back everything up
    http://forum.xda-developers.com/oneplus-one/general/guide-return-opo-to-100-stock-t2826541
    #87
    Spannaa likes this.
  8. Jan Vander Auwera
    Cupcake Nov 24, 2014
    Jan Vander Auwera , Nov 24, 2014 :
    I went to that page, but what does this mean:
    "if you don't have adb/fastboot in your Path, extract the image into your adb/fastboot folder"?
    Should i just create this path and extract "cm-11.0-XNPH44S-bacon-signed-fastboot_64GB" to there?
    #88
  9. Spannaa
    KitKat Nov 24, 2014
    Spannaa , Nov 24, 2014 :
    The default folder for adb & fastboot is C:\Program Files\Android\android-sdk\platform-tools
    Either append the path to this folder to your PATH system environment variable and run fastboot from anywhere OR extract the zip to this folder and run fastboot from there.
    #89
  10. Theendgamelv3
    Froyo Nov 24, 2014
    Theendgamelv3 , Nov 24, 2014 :
    I need to update my phone as well as I am running 33R. How would I use a OTA incremental update zip to update my phone?
    #90
  11. omiroks
    Jelly Bean Nov 24, 2014
    #91
  12. omiroks
    #92
  13. Jan Vander Auwera
    #93
  14. Spannaa
    KitKat Nov 24, 2014
    You could flash the OTA incremental update zips in sequence until you get to the build you want to be on, rebooting between each flash to make sure everything is OK.
    22R -> 25R then 25R -> 30O then 30O -> 33R etc.
    Make sure you flash the correct zips though - look at the numbers/letters in the zip names.
    If that's still too "developer" for you, you could try using Wug's Bacon Root Toolkit
    #94
  15. Jan Vander Auwera
    Thanks for the information.
    I have tried the OTA incremental zip "cm-bacon-03d77315ea-to-d22b777afa-signed", just copied the zip-file to my phone and then tried to update via the reboot menu. That also didn' work.
    Do you also have tips for a good driver for my OPO, I have tried the "Samsung_USB_Drivers_for_Mobile_Phones_1.5.9.0" but that didn't work.
    #95
  16. Spannaa
    KitKat Nov 24, 2014
    That's probably Samsung specific.
    The 15 seconds ADB Installer v1.4.2 should include everything you need ;)
    #96
  17. Jan Vander Auwera
    I have used the "Bacon Root Toolkit" When i try to configure ADB, I get this error:
    What should i do? I followed all the instructions. My PC is running under Windows Vista.
    #97
  18. Jan Vander Auwera
    #98
  19. Spannaa
    KitKat Nov 24, 2014
    #99
  20. barduar
    Eclair Nov 25, 2014
    barduar , Nov 25, 2014 :
    HELP
    Im about to ditch the phone,
    • I can't root (doing all the correct steps)
    • NO UPDATES WORK
    • No updates come up in about phone.
    Now i regret not buying the note 4! Please help!
    I'm on mac 10.6.8
