765
Mirrors for official Cyanogen roms & OTA updates
  1. moritz041998
    Cupcake Aug 4, 2015
    moritz041998 , Aug 4, 2015 :
    I am currently running the stock cm12s YNG!TAS17L and want to upgrade to YNG!TAS2I3 but I am running TWRP and therefore don't want to update the Cyanogen Recovery. But if I want to flash the YNG1TAS17L -> YNG1TAS2I3 zip it is giving me an error.
  2. Spannaa
    KitKat Aug 4, 2015
    Spannaa , Aug 4, 2015 :
    Just use the full, signed flashable zip then ;)
    moritz041998 likes this.
  3. prasoonkumarkp
    Gingerbread Aug 5, 2015
    prasoonkumarkp , Aug 5, 2015 :
    i tried to install the OTA update but its not working. I had been using my OPO in CM nightly version and yesterday i changed it back to the Stock ROM version but then there showed a notification saying that one update is available but then you already know what happened. What can i do.. it makes me very uncomfortable watching the notification message which i cant update.
  4. Spannaa
    KitKat Aug 5, 2015
    Spannaa , Aug 5, 2015 :
    "It's not working" doesn't really help.
    What was the exact error message...
  5. franguerriacc
    Cupcake Aug 7, 2015
    franguerriacc , Aug 7, 2015 :
    Hi, how are you? currently I have version 2I3 cm12s but I can not root this and saw that there is a version of 2I3 root, I can install this version with the recovery of cyanogen officer? Sorry if something is poorly written because it does not speak English and I'm doing with the translator :)
  6. Spannaa
    KitKat Aug 7, 2015
    Spannaa , Aug 7, 2015 :
    No, you need a custom recovery to install the stock rooted version which also means you'll have to unlock your bootloader.
    If you're going to do this then its just as easy to root your phone using SuperSU.
    If you can't manage it manually, use Wugs bacon toolkit.
  7. alkie31
    Gingerbread Aug 7, 2015
  8. yuvrajpardeshi
    Cupcake Aug 9, 2015
  9. Mr. James
    Eclair Aug 9, 2015
    Mr. James , Aug 9, 2015 :
    I get error when I try to flash cm12 with TWRP. The rom not load. Oxygen works fine.
    any problem with the last version of twrp? another version is best?
  10. Spannaa
    KitKat Aug 9, 2015
    Spannaa , Aug 9, 2015 :
    Exactly what zip are you trying to flash and what version of twrp are you running?
  11. mrchdavid
    Gingerbread Aug 10, 2015
    mrchdavid , Aug 10, 2015 :
    Been running SlimSaber Rom. Clean,quick and great battery life. Running SlimKernal from Fusionjack. Android 5.1.1 :)
  12. Snooky092
    Honeycomb Aug 11, 2015
    Snooky092 , Aug 11, 2015 :
    Hi @Spannaa,
    I'm from Belgium and since the update to CM12 I have problems with my wifi and my 4G-connection does not work at all.
    Found some solutions on the forum, but all of them needed root (and my OPO is not rooted, and I dont want it rooted).
    I downloaded the latest CM11 zip-file from your thread, Unofficial-cm-11.0-XNPH05Q-bacon-signed.zip , but what do I need to do next? Is this the exact file I need and what do I have to do to get it on my OPO? I cant find a link or a manual how to install this file on my OPO?
    greetz,
    Danny
  13. Spannaa
    KitKat Aug 11, 2015
    Spannaa , Aug 11, 2015 :
    You boot into recovery and flash it.
    You need a custom recovery to do this though which means you have to unlock your bootloader first (and doing this will wipe your data and userdata).
    You could also use a fastboot zip but you'd still need an unlocked bootloader.
    Snooky092 likes this.
  14. apok010
    Gingerbread Aug 12, 2015
    apok010 , Aug 12, 2015 :
    Can anyone tell me when COS12.1 will be released? I know it's Soon™... But a more precise idea or date :)
    Cheers
    Prophet17 likes this.
  15. Spannaa
    KitKat Aug 12, 2015
    Spannaa , Aug 12, 2015 :
    Only OnePlus & Cyanogen know...
    Does it really matter - it'll probably be way behind the nightlies.
  16. apok010
    Yeah I know.
    For me, I'm OK with the nightlies but I'm planning to change phone and give my OPO to my girlfriend, so I want to deliver it in mint state (hardware and software). Anything after is her fault... Lol
  17. Ashkeroth
    Eclair Aug 14, 2015
  18. Spannaa
    KitKat Aug 14, 2015
    Spannaa , Aug 14, 2015 :
    All of them?
    Try updating/changing the version of TWRP you're using.
  19. Ashkeroth
    Eclair Aug 15, 2015
  20. kunalJ1412
    Donut Aug 16, 2015
