765
Mirrors for official Cyanogen roms & OTA updates
  1. Pikolo226
    Donut Sep 4, 2015
  2. TheDutch101
    Froyo Sep 7, 2015
    TheDutch101 , Sep 7, 2015 :
    question:
    I'm using a 12.1 NIGHTYLY-bacion version (it's a bit old, 20150426, i was a lazy updater), rooted, and using the latest TWRP update, (android 5.1.1).
    Should I use a signed fastboot zip or a signed flashable zip?
    I'm worried that I'll lose many things on my phone when using the signed fastboot (and I'm not sure how to backup everything to not lose stuff) and the flashable zip seems like a much easier option to use. What would you advice @Spannaa?
  3. Spannaa
    KitKat Sep 7, 2015
    Spannaa , Sep 7, 2015 :
    Personally, I'd advise using cm-12.1-20150905-NIGHTLY-bacon.zip :D
    If you really want to move to COS12.1, the flashable zip should be fine. You should wipe everything except internal storage (and USB OTG) though as it's a different rom and you'll have problems if you don't.
    You could use the fastboot files, wipe internal storage and not fastboot flash the userdata partition image instead.
    TheDutch101 likes this.
  4. TheDutch101
    Froyo Sep 7, 2015
    Thanks! I think it works. No noticeable errors.
    The first thing that pops up is a message that new nightlies are available to download, if I decide to update that so now and then.. is there an app that can be used for that or do I just need to do that right through trwp again? Or do I have to back it all up as well? That's all I need to know to get going.
  5. Spannaa
    KitKat Sep 7, 2015
    You can update to newer nightlies via the updater built in to settings or you can download and flash via twrp.
  6. TheDutch101
    Froyo Sep 7, 2015
    awesome, thank you.
    Spannaa likes this.
  7. shadowX159
    Ice Cream Sandwich Sep 14, 2015
    shadowX159 , Sep 14, 2015 :
    So is there going to be a rooted version of the ROM or can we just flash the stocked ROM with SuperSU and call it a day?
  8. Spannaa
    KitKat Sep 14, 2015
    Spannaa , Sep 14, 2015 :
    I don't know - I'm only mirroring them!
    Stock + SuperSU is fine.
  9. Deactivated User
    Sep 15, 2015
  10. Spannaa
    KitKat Sep 15, 2015
    Spannaa , Sep 15, 2015 :
    You probably need to wipe data before flashing too if you're downgrading from COS12 or CM12
  11. Deactivated User
    Sep 15, 2015
  12. Spannaa
    KitKat Sep 15, 2015
    Yep.
    The firmware is included in the zip so you should be OK with just that.
    If it goes wrong, fastboot flash the contents of the fastboot zip instead.
    Deactivated User likes this.
  13. Deactivated User
    Sep 15, 2015
  14. Deactivated User
    Sep 15, 2015
  15. Spannaa
    KitKat Sep 15, 2015
    As I said, if it goes wrong, fastboot flash the contents of the fastboot zip instead.
    Just "fastboot flash system system.img" should be enough.
  16. trackydj
    Gingerbread Sep 17, 2015
    trackydj , Sep 17, 2015 :
    Hi,
    I'm a bit of a newbie to flashing tho have done a couple of devices after following guides from www.
    Trawling through various threads on here I cannot make sense of what is the right or wrong way?
    Do not want to brick my One! :)
    Looking at going back to CM11 from CM12, not sure what version yet, are there any issues that I may encounter doing this?
    Thanks.
  17. Spannaa
    KitKat Sep 17, 2015
    Spannaa , Sep 17, 2015 :
    No, not if you do it correctly ;)
  18. trackydj
    Gingerbread Sep 22, 2015
    trackydj , Sep 22, 2015 :
    Well I have followed the guide by timmaaa and have managed to go back to cm11 from cm12 and all seems OK.
    However
    When I now go into recovery I don't see twrp that I installed, all I have is cynogen basic recovery.
    What have I done wrong?
  19. Spannaa
    KitKat Sep 22, 2015
    Spannaa , Sep 22, 2015 :
    Did you
    fastboot flash recovery recovery.img
    If so, there's your answer.
  20. trackydj
    Gingerbread Sep 23, 2015
