765
Mirrors for official Cyanogen roms & OTA updates
  1. steele532
    Donut Jan 16, 2016
    steele532 , Jan 16, 2016 :
    Hey man I was joking. I didn't mean to stress you out. Sorry for that.
  2. saisakthi
    Donut Jan 16, 2016
  3. beltway
    Gingerbread Jan 16, 2016
    beltway , Jan 16, 2016 :
    Changed to Hexo theme, rebooted and installed the full ZIP in TWRP, cleared cache and Dalvik, installed SuperSU again, rebooted, waited a few minutes at the Cyanogen boot screen, put the phone aside while it updated apps, picked it up a few minutes later and set up Cortana. Things seem OK. Thanks again for the thread, Spannaa!
  4. Lord Boeffla
    Recognized developer Recognized Developer Jan 16, 2016
    Lord Boeffla , Jan 16, 2016 :
    Can't help.
    Sorry, but don't expect anything when posting such a useless information. Unbelievable...
  5. Spannaa
    KitKat Jan 16, 2016
    Spannaa , Jan 16, 2016 :
    Update:
    Added YOG7DAS2K1 signed fastboot zip, signed zip & boot-debuggable img to post #1
    Thanks to @Lord Boeffla for the availability heads-up
  6. jstepa
    KitKat Jan 16, 2016
    jstepa , Jan 16, 2016 :
    Thanks to you for your valuable job :)
    Spannaa likes this.
  7. FerryFast
    Cupcake Jan 16, 2016
  8. Mattonair
    Mattonair , Jan 16, 2016 :
    Thanks, Spannaa. Downloaded it - installed - everything wonderful. Thx for your great job!
  9. b1t
    b1t , Jan 16, 2016 :
    finally... the system update notification was starting to bug me a lot.
  10. covelinhas
    Cupcake Jan 17, 2016
  11. axbrandao
    Gingerbread Jan 17, 2016
    axbrandao , Jan 17, 2016 :
    Friend, this update is official and can only be applied using the stock recovery
  12. vinaysharma76
    Eclair Jan 17, 2016
    vinaysharma76 , Jan 17, 2016 :
    it worked with TWRP and su also flashed successfully.
  13. Spannaa
    KitKat Jan 17, 2016
    Spannaa , Jan 17, 2016 :
    The full zip can be flashed via TWRP or stock recovery.
    It's only the OTA that's stock only.
    ScorpioPirate likes this.
  14. covelinhas
  15. ScorpioPirate
    Ice Cream Sandwich Jan 17, 2016
  16. fpavoncelli
    Froyo Jan 17, 2016
    fpavoncelli , Jan 17, 2016 :
    I have flashed with TWRP the latest version from the link above, and I don't see any trace of Cortana. My OPO is European if it makes a difference but I've been updating it with the files from this thread for quite a while. Any clue ?
  17. Funk Wizard
    Lollipop Moderator Jan 18, 2016
  18. beltway
    Gingerbread Jan 18, 2016
    beltway , Jan 18, 2016 :
    I see your baseband version is different from mine:
    (00230 versus 00241)
    It's possible that different regions have different baseband versions, but it seems more likely that it might not have been updated during the flash. Maybe you can check with other Euro OPO users who used stock recovery and/or a different version of TWRP.
    Another update a few months ago had an issue with the baseband not being updated by TWRP v2.4.0.7. I had that problem and was told about the issue and to revert to TWRP v.2.4.6.0 (I used Flashify) and re-flash the full ZIP. The baseband was updated correctly after that and I am still using v2.4.6.0 because it seems to work well.
    Hope this helps and good luck.
  19. daniga74
    Jelly Bean Jan 18, 2016
    daniga74 , Jan 18, 2016 :
    you have to use TWRP 2.8.6.0; above versions have a problem to flash baseband correctly
    Spannaa likes this.
  20. Spannaa
    KitKat Jan 18, 2016
    Spannaa , Jan 18, 2016 :
    Yep, the links went live on Friday evening and I updated post #1 on Saturday morning ;)
    It's useful to have the official links in the thread too (for the suspicious & paranoid users) though :D
    Funk Wizard likes this.
