501
Mirrors for official Oxygen OS ROMs and OTA updates
  1. sir_gpm
    Froyo Oct 31, 2015
  2. daninantro
    Ice Cream Sandwich Oct 31, 2015
  3. Deactivated User
    Oct 31, 2015
  4. Hafiz5635
    Honeycomb Oct 31, 2015
    Hafiz5635 , Oct 31, 2015 :
    Hydrogen have bugs.. Its about the notification dont show up..
  5. Hafiz5635
    You did not found or you missed look at it.. Its all about notification..
  6. willy156
    Honeycomb Nov 3, 2015
    willy156 , Nov 3, 2015 :
    Hi Spanna. I have 2.1.0. Can I download and flash the 1.1 GB file of 2.1.1 instead of flashing the increment 2.1.0 > 2.1.1? The increment 2.1.1 does not work for me as I get "installation failed."
  7. Spannaa
    KitKat Nov 3, 2015
    Spannaa , Nov 3, 2015 :
    Yep, should be OK.
  8. sir_gpm
    Froyo Nov 3, 2015
    sir_gpm , Nov 3, 2015 :
    Is just about the proper configuration of the notification. They work fine for me.
  9. Hafiz5635
    Honeycomb Nov 4, 2015
    Hafiz5635 , Nov 4, 2015 :
    Yeah it should work if you tick the notification for apps. more, the weather also cant be used and gps / location too.
    sir_gpm likes this.
  10. Hafiz5635
    Bro spannaa, can you give setting for synapse using AK kernel here?
  11. nbajpai9
    Gingerbread Nov 4, 2015
  12. Spannaa
    KitKat Nov 4, 2015
    Spannaa , Nov 4, 2015 :
    I'm still experimenting - wait for Stylo King @ XDA - his settings will be much better than mine.
  13. Hafiz5635
    Stylo King still not review his setting in XDA. He just leave others to comment in his thread. Well, it good to try your setting of synapse if you dont mind. Share with me. Im glad to try it.
  14. Spannaa
    KitKat Nov 4, 2015
    As I said, I'm still experimenting and haven't bothered saving a profile or config yet.
    Read the profiles thread and experiment for yourself - your usage will be different to mine so you'll probably need different settings to me.
  15. Hafiz5635
    ok.what version of ak do you use?
  16. Spannaa
    KitKat Nov 4, 2015
    The latest: AK.021.OP2.OXYGEN
  17. igorerzen
    Donut Nov 4, 2015
  18. abadiloveyou
    Gingerbread Nov 5, 2015
  19. jgchaval
    Cupcake Nov 6, 2015
    jgchaval , Nov 6, 2015 :
    Hi All,
    I have several doubts regarding rooting and still being able to update OxygenOS. Let's assume my device is already rooted, unlocked bootloader and with TWRP:
    * If I want to update Oxygen OS, I must do that by flashing the complete ROM zipfile, correct?
    * Do I loose root and TWRP everything I flash any update or new Oxygen OS ROM zipfile? Do I have to re-root and install TWRP after every Oxygen OS ROM install?
    * Do flashing full Oxygen OS ROM zipfile delete my data, or I can flash it and my phone will boot normally as it was before but updated?
    Many thanks! Sorry if this has been asked before, I will soon receive my OP2 :D
  20. Spannaa
    KitKat Nov 7, 2015
    Spannaa , Nov 7, 2015 :
    1. Yes, that's the easiest way.
    2. You lose root, but not TWRP. You can just re- flash the SuperSU zip straight after the rom zip
    3. Flashing the full zip doesn't touch your userdata or apps.
    jgchaval likes this.
