501
Mirrors for official Oxygen OS ROMs and OTA updates
  1. jgchaval
    Cupcake Nov 7, 2015
    jgchaval , Nov 7, 2015 :
    Thanks a lot for your answer! And I assume that besides re-flashing SperSU I also need to re-flash any custom Kernel after every OxygenOS ROM update, correct?
  2. Spannaa
    KitKat Nov 7, 2015
    Spannaa , Nov 7, 2015 :
    Yep, and any system mods such as Xposed etc.
    jgchaval likes this.
  3. backoffindia
    Donut Nov 7, 2015
    backoffindia , Nov 7, 2015 :
    everything i need in one thread. thank you all
  4. Keenaicker
    Eclair Nov 11, 2015
  5. shinoy.sharma
    Froyo Nov 12, 2015
    shinoy.sharma , Nov 12, 2015 :
    Thanks for keeping it updated :)
  6. fxguru77
    Jelly Bean Nov 13, 2015
  7. elonepluso
    Eclair Nov 13, 2015
    Flyologist, Greenflash and fxguru77 like this.
  8. inffy
    KitKat Nov 13, 2015
  9. ajin123
    Gingerbread Nov 13, 2015
    ajin123 , Nov 13, 2015 :
    I am running AK kernel and root
    Whats the procedure I have to follow to get the update?
    Please help.
  10. souvikdas95
    Ice Cream Sandwich Nov 13, 2015
    inffy likes this.
  11. inffy
    KitKat Nov 13, 2015
    inffy , Nov 13, 2015 :
    But i was FIRST :D
  12. souvikdas95
    souvikdas95 , Nov 13, 2015 :
    Sorry bro. It seems there's a patch for boot.img. In other words, kernel is patched too. AK and Boeffla use older kernel. Installing 'em will only break the updates or may end up bricking your phone.
  13. Greenflash
    Froyo Nov 13, 2015
    Greenflash , Nov 13, 2015 :
    First you have to flash full 2.1.1, then you can flash the update (2.1.2). After that you can flash your kernel.
  14. souvikdas95
  15. ajin123
    So I need to go back to stock and then install the OTAs there is no other way?
    Current setup is working fine.
    What will be another solution ?
    AK will release and Update and then I can flash the Full Rom and and update?
  16. souvikdas95
    Yeah you can do that. Wait for AK to update their source to 2.1.2 stock kernel. But that won't be clean. They would themselves recommend atleast dirty flash.
  17. nh_opu
    Froyo Nov 13, 2015
    elonepluso likes this.
  18. ajin123
    Sorry souvik for asking again.
    As per you going back to stock is the best option if i want to receive the update.?
    Can you help me with how to uninstall the kerenl
    I have checked in google and this is What i found
    "[ UNINSTALL UKM & AK KERNEL ]
    What my kernel does is:
    # Rename mpdecsion binary
    mv $ bindir / mpdecision $ bindir / mpdecision-rm
    if you want you can return by renaming "mpdecision", and than reboot the phone.
    It was enough to report it in my thread.
    however, I have created a zip for revert after seeing this exchange:
    http://ak.hiddenbytes.org/
    UKM_AK_uninstaller_v4.zip"
    this means i have to flash that "UKM_AK_uninstaller_v4.zip" After that i will be all fine ?
    Please advice with noob level steps :(:oops::oops:
  19. Spannaa
    KitKat Nov 13, 2015
    locxFIN likes this.
  20. souvikdas95
    I am not an expert at it either. I just know it uses the older kernel and modifies it. You can try if you want as people say it doesn't brick. But, at the same time, it's not updated either.
