501
Mirrors for official Oxygen OS ROMs and OTA updates
  1. yanowman
    Gingerbread Nov 17, 2015
  2. Spannaa
    KitKat Nov 17, 2015
    Spannaa , Nov 17, 2015 :
    If you're rooted or have any system mods, it's the only way.
    Why do people keep asking this?
    You don't need the full 2.1.2 zip to upgrade.
  3. Spannaa
    KitKat Nov 17, 2015
  4. Knapneder
    Cupcake Nov 17, 2015
    Knapneder , Nov 17, 2015 :
    How would you install it other than in stock recovery? If it's not possible then I have tried everything.
  5. elonepluso
    Eclair Nov 17, 2015
    elonepluso , Nov 17, 2015 :
    You can _not_ install fullrom in stock recovery!
    You _need_ TWRP for this.
  6. zeitlins
    Eclair Nov 17, 2015
    zeitlins , Nov 17, 2015 :
    I am not getting an error it just stops at patching system (stays there forever)
  7. Spannaa
    KitKat Nov 17, 2015
    via TWRP?
  8. zeitlins
    Eclair Nov 17, 2015
  9. zeitlins
    Eclair Nov 17, 2015
  10. sabbeman
    Eclair Nov 17, 2015
    sabbeman , Nov 17, 2015 :
    Even if you have a rooted device???
    That's new!
    Even if have a rooted device???!
    Well that's new!
    You wrote:
  11. Spannaa
    KitKat Nov 17, 2015
    You misunderstand!
    You don't need the full 2.1.2 zip because you can:
    Boot into TWRP recovery
    • Flash the 2.1.1 full rom zip
    • Flash the 2.1.2 OTA incremental update zip
    • Flash the SuperSU zip
    • Reboot
    The result is exactly the same as if you'd flashed a 2.1.2 full rom zip.
  12. sabbeman
    Eclair Nov 17, 2015
    OK! Then it's my bad!
    I like many others have misunderstood you wrote!
    I didn't think I could use the OTA file.
  13. Spannaa
    KitKat Nov 17, 2015
    You can if you flash the clean, unrooted 2.1.1 full zip first.
  14. sabbeman
    Eclair Nov 17, 2015
    Well I'm running a rooted device with OOS 2.1.1
    Do I really have to unroot by installing the clean unrooted 2.1.1? Won't that erase all my settings?
    Wouldn't it be easier just to provide the full zip like before?
    I tried installing the OTA via twrp and it didn't work. Check the uploaded screenshot.
  15. sabbeman
    Eclair Nov 17, 2015
    I tried it just as you wrote here + cleaned the Cach & Dalvik cach before reboot!
    Seems like it's working! Phone is starting and optimizing apps as I'm writing right now.
    Hope It won't have to be like this every time an new OTA comes!
  16. elonepluso
    Eclair Nov 17, 2015
    I guess it is not working since you have received an error...
    Optimizing apps is just because you cleared cache and dalvik...
    I assume you have _not_ flashed 2.1.1. fullrom before the patch and that's why it failed...
  17. sabbeman
    Eclair Nov 17, 2015
    Correct assumptions!
    I redid it as I wrote above and it worked fine :)
  18. elonepluso
    Eclair Nov 17, 2015
    So welcome to 2.1.2 finally... :D
    sabbeman likes this.
  19. Spannaa
    KitKat Nov 17, 2015
    As I've said on numerous occasions: Flashing the clean unrooted 2.1.1 won't erase your settings or delete your data.
    Your flash didn't fail because you used TWRP, it failed because you were rooted.
    "/system/bin/install-recovery.sh has unexpected contents"
    /system/bin/install-recovery.sh is replaced by the SuperSU zip when you root so, your rom wasn't completely stock.
  20. Flyologist
    Jelly Bean Nov 17, 2015
    Flyologist , Nov 17, 2015 :
    I noticed with this new update 2.1.2 Ota zip finger scan does not work at all after I flashed it, so I went back to 2.1.1 instead .... @Spannaa any help..
