500
Mirrors for official Oxygen OS ROMs and OTA updates
  1. Spannaa
    KitKat Dec 21, 2015
    Spannaa , Dec 21, 2015 :
    Just ignore both errors, you're fine if you flashed both zips and you're up and running.
    First error is because even though the zip is signed, there's no md5 for twrp to check.
    Second error is probably because the update binary doesn't understand a line in the updater script.
    pure.by likes this.
  2. pure.by
    Gingerbread Dec 21, 2015
    pure.by , Dec 21, 2015 :
    Thanks for the explanation!
    Meanwhile, I am up and running, no issues so far :)
  3. rs98
    Ice Cream Sandwich Dec 21, 2015
    rs98 , Dec 21, 2015 :
    With that alternate method of flashing the full rom then the incremental zip, do i have to download the newest full rom each time, or can i just do, say next time, the full 2.1.2, ota for 2.2, then ota again for 2.2.1?
  4. Spannaa
    KitKat Dec 21, 2015
    Yes, full rom zip and then sequential ota update zips will work.
    pure.by and rs98 like this.
  5. ozikat12
    Froyo Dec 22, 2015
    Flyologist likes this.
  6. lukebordy
    Honeycomb Dec 22, 2015
  7. Anzik
    Ice Cream Sandwich Dec 22, 2015
    Anzik , Dec 22, 2015 :
    Yes
  8. ozikat12
    Froyo Dec 22, 2015
    ozikat12 , Dec 22, 2015 :
    Download full zip 2.1.2 and OTA 2.1.2 to 2.2.0
    1. Flash 2.1.2 zip (So it became Unroot)
    2. Flash OTA 2.1.2 -> 2.2.0
    3. Flash SuperSu
    It will work, at least mine did work.
    Orenhsh and Spannaa like this.
  9. Spannaa
    KitKat Dec 22, 2015
    Spannaa , Dec 22, 2015 :
    Getting fed up with having to answer this question over and over again. Doesn't anyone read before posting?
    Answer: No - read the note in the first post...
    ozikat12 likes this.
  10. ozikat12
    Froyo Dec 22, 2015
    I think people over excited with upgrade and forgot to read.. 1st post, even they read, they don't start with... 1st line :p
  11. Spannaa
    KitKat Dec 22, 2015
    No...
    Don't bother posting if you don't know the answer!
  12. Spannaa
    KitKat Dec 22, 2015
    You're very generous!
    Most people in these forums are just lazy and can't be bothered reading or searching...
  13. ozikat12
    Froyo Dec 22, 2015
    Because there is no Google search bar in OnePlus forums :p heheeh...
  14. rlacerda
    Gingerbread Dec 22, 2015
    rlacerda , Dec 22, 2015 :
    Actually, due to some problems with the 2.1.2, they shall be afraid to upgrade to 2.2.0 passing by 2.1.2. :confused:
    I had a hard time with 2.1.2 due to the wifi problem (I actually had to do a full wipe to have my wifi back with version 2.0.0). However, I manage to install 2.2.0 installing 2.1.2 OTA followed by 2.2.0 OTA. :D
  15. gautamhans1
    Honeycomb Dec 23, 2015
  16. Anzik
    Ice Cream Sandwich Dec 23, 2015
  17. gautamhans1
  18. gautamhans1
  19. Eshan_Anand
    Jelly Bean Dec 23, 2015
  20. Anzik
    Anzik , Dec 23, 2015 :
    I have a lot of lags on 2.2.. Will revert to 2.1.2 and stay on it, until android M is come out..
