499
Mirrors for official Oxygen OS ROMs and OTA updates
  1. nbmartinbr
    Donut Oct 22, 2015
    nbmartinbr , Oct 22, 2015 :
    Hello Spannaa,
    I have OP2 and I got the notif (OTA) to install OxygenOS 2.1.1
    But when installing it, it failed.
    Is there a bug with this OTA release?
    How can I upgrade my current 2.0.0 OxygenOS release to the latest one?
    Thank you,
    Regards,
    Bruno
  2. intrigueleo
    Cupcake Oct 22, 2015
    intrigueleo , Oct 22, 2015 :
    No to seems to be dead after the latest OTA updates my friend.
    One plus has informed me that they will take a remote session and try flashing the ROM.
  3. Spannaa
    KitKat Oct 22, 2015
    Spannaa , Oct 22, 2015 :
    Just flash the latest, full Signed flashable zip.
  4. kwchoi1213
  5. nbmartinbr
    Donut Oct 22, 2015
    Can you tell/explain how I can flash it?
    Thank you,
    Rdgs
    Bruno
  6. Spannaa
    KitKat Oct 22, 2015
    Download the zip to your phone, boot into recovery, select the zip and flash it.
    If you don't know how, search the forums and you'll find detailed instructions ;)
  7. 0101ics
    Donut Oct 22, 2015
  8. 0101ics
    Donut Oct 22, 2015
    0101ics , Oct 22, 2015 :
    Is there any chance to have also a collection of radios/modems?
    Regards,
    Me
  9. t.zarouri
  10. Spannaa
    KitKat Oct 22, 2015
    Yes.
    Just extract them from the full zips ;)
    0101ics likes this.
  11. ahmed_chougle
    ahmed_chougle , Oct 22, 2015 :
    i am getting an error update binary failed when i try to flash oxygen os2.1.1 ota
  12. 0101ics
    Donut Oct 22, 2015
    Do you know if only Radio can be separately flashed and which is the procedure?
    Are there any diferences between A2001 / A2003.
    Thanks!
  13. Spannaa
    KitKat Oct 22, 2015
    There should be another error message that says why.
  14. Spannaa
    KitKat Oct 22, 2015
    Yes, you can fastboot flash just the radio:
    Code:
    fastboot flash oem_stanvbk static_nvbk.bin
    AFAIK, A2001, A2003 & A2005 all use the same rom & radio.
    0101ics likes this.
  15. kyril13
  16. dr.karthik k
    Gingerbread Oct 22, 2015
    dr.karthik k , Oct 22, 2015 :
    does anybody having probelm with op2 while using camera with flash?? when i m using my camera with flash my mobilescreen is suddenly off please anyone can help me??
  17. 0101ics
    Donut Oct 22, 2015
    I have an error: FAILED (remote: device is locked. Cannot flash images)
    I have tried: fastboot oem unlock and I have: FAILED (remote: device is locked. Cannot flash images)
    Any advice?
    Thank you
  18. Spannaa
    KitKat Oct 22, 2015
    Is OEM unlocking toggled on in Developer Options?
    0101ics likes this.
  19. mandeepjosan
    mandeepjosan , Oct 22, 2015 :
    What about opo buddy? @Spannaa
  20. Spannaa
    KitKat Oct 22, 2015
    I'll let you cover that since I don't have a OPO anymore and I never used Oxygen on it ;)
    mandeepjosan likes this.
