500
Mirrors for official Oxygen OS ROMs and OTA updates
  1. p_anuram
    Donut Jul 15, 2017
  2. Fludizz
    Donut Jul 19, 2017
    Fludizz , Jul 19, 2017 :
    The OTA update that I got today fails to flash on my (Fully encrypted) phone as I do not have any unencrypted partitions for it to store the update file in. Manual update instructions mention that I should put it on the root of the SD-card, that's not going to work either, LOL.
    Will try side-loading the Incremental ZIP some other time to see if that works.
    [edit]
    Yep, sideloading worked perfectly fine :)
  3. Anoop0
    Gingerbread Jul 25, 2017
    Anoop0 , Jul 25, 2017 :
    After incremental update failed. Phone automatically asked to download full 3.6.0 package and installed it.
    After installation my Root access and TWRP gone. I tried flashing SU but didn't worked.
    I forget what I did earlier to get things back. Can anyone tell me steps to get TWRP and SU without loosing data?
    Thanks.
  4. Spannaa
    KitKat Jul 25, 2017
    Spannaa , Jul 25, 2017 :
    There's a guide in post #1 of this thread on XDA that covers what you need to know and the TWRP & SuperSU to use are linked in post #1 of this thread.
    Anoop0 likes this.
  5. laurboss
    Honeycomb Jul 28, 2017
    laurboss , Jul 28, 2017 :
    @Spannaa Can i have acces to download the 3.6.0 zip? I get the following error:
    OnePlus2Oxygen_14_OTA_031_all_1706262034.zip
    access denied
    looks like you don't have permission to access this folder. Make sure you are signed in to an account that has permission, or check with the developer to request access.
    Thanks.
  6. mitomon
    Cupcake Jul 28, 2017
  7. VORT3X03
    Donut Jul 28, 2017
    VORT3X03 , Jul 28, 2017 :
  8. mitomon
    mitomon , Jul 28, 2017 :
    I'm registered , still don't have access , once i had access, i send a mail trough contact.
  9. kallekula33
    Lollipop Aug 15, 2017
    kallekula33 , Aug 15, 2017 :
    Can I jump from 3.1.0 to 3.6.0 flashing the full signed zip? I'm rooted so I can't take the OTA. But dirty flashing it via TWRP should work right?
  10. Spannaa
    KitKat Aug 15, 2017
    Spannaa , Aug 15, 2017 :
    You can try!
    Nandroid and wipe caches first and then, if it doesn't work, wipe data and try again.
  11. kallekula33
    Well, yeah, I could always try.... What could possibly happen ;).
    Do I need to consider upgrading TWRP first? I know that there are newer versions from what I got. Don't even remember the version number.
  12. Spannaa
    KitKat Aug 16, 2017
    Spannaa , Aug 16, 2017 :
    The version of TWRP you used to flash OOS 3.1.0 should be fine to flash 3.6.0 but there's no harm in upgrading to the latest version.
  13. G_Abhineet_Kumar_qtyJ
    Cupcake Aug 24, 2017
  14. Spannaa
    KitKat Aug 24, 2017
    Spannaa , Aug 24, 2017 :
    Not enough information...
  15. Gunkjcvjurd
    Eclair Sep 10, 2017
  16. rahmannek
    Honeycomb Sep 28, 2017
  17. Spannaa
    KitKat Sep 28, 2017
    Spannaa , Sep 28, 2017 :
    Trolling will get you nowhere - kindly keep your sad, bitter comments out of this thread :rolleyes:
    Rusty NZ and kaihp like this.
  18. Rusty NZ
    Marshmallow Oct 9, 2017
    Rusty NZ , Oct 9, 2017 :
    Spamming the threads
    Edit, the spam I was referring to had been deleted after being reported
    Spannaa and 4u5t1n like this.
  19. jizang
    Lollipop Oct 15, 2017
    jizang , Oct 15, 2017 :
    but spamming gets you more raffles :p
  20. Spannaa
    KitKat Oct 16, 2017
    Spannaa , Oct 16, 2017 :
    Not if you're reported and your posts are removed :cool:
    kaihp and Rusty NZ like this.
