500
Mirrors for official Oxygen OS ROMs and OTA updates
  1. Fludizz
    Donut Oct 16, 2017
    Fludizz , Oct 16, 2017 :
    What are the odds that OnePlus will release a fix for the recently published WPA2 vulnerabilities (and not to mention the Bluetooth vulnerabilities)?
    I do like the OxygenOS ROM, but if they will never release a patch for these security issues, I'm afraid a custom ROM is the only way forward :( Based on the little detail that the last android security update is the 1st of June patch, I'm skeptical...
    4u5t1n likes this.
  2. kaihp
    Jelly Bean Oct 16, 2017
    kaihp , Oct 16, 2017 :
    Somewhere between "hell freezes over" and we discover faster than light travel.
    Rusty NZ, Spannaa and Fludizz like this.
  3. Rusty NZ
    Marshmallow Oct 16, 2017
    kaihp and 4u5t1n like this.
  4. kaihp
    I had a feeling that someone would comment on f-t-l travel :D
    Einstein's general relativity theory doesn't rule out f-t-l speeds, but crossing from below to above lightspeed requires infinite energy according to it. Light interference patterns (e.g. the maximas) can move f-t-l, but this doesn't move information so it isn't very interesting.
    As for hell freezing over, it depends on which hell you use as a reference. In Dante's Inferno, the innermost (9th) level is described as being very very cold, whereas it is hot according to the New Testament.
    So in the end there might be a 3.6.1 release to fix the wpa_supplicant before the end of the year ... but I doubt it :cool:
    Spannaa, 4u5t1n and Rusty NZ like this.
  5. Titokhan
    Honeycomb Oct 26, 2017
    Fludizz, dejan16v, daster_x and 4 others like this.
  6. dr.diem
    Froyo Oct 26, 2017
    Titokhan likes this.
  7. demnogis
    Cupcake Oct 27, 2017
  8. Titokhan
    Honeycomb Oct 27, 2017
    Spannaa likes this.
  9. Spannaa
    KitKat Oct 27, 2017
    Spannaa , Oct 27, 2017 :
    Added Oxygen OS 3.6.0 > Oxygen OS 3.6.1 OTA incremental update zip & Oxygen OS 3.6.1 signed flashable zip to post #1 of my XDA Oxygen OS Mirrors thread.
    Changelog:
    • Updated Android security patch level to October 2017
    • Fixed WPA2 security issue
    • General bug fixes and improvements
  10. MasterPoiuy
    Gingerbread Oct 27, 2017
    MasterPoiuy , Oct 27, 2017 :
    Has the OTA from 3.6.0 to 3.6.1 zip verified? I just tried to dirty flash and it gives me updater error 7 in TWRP..
  11. Spannaa
    KitKat Oct 27, 2017
    Verified? - It comes directly from OnePlus.
    Are you rooted? If you are, that's why.
    OTA updates only work on non-rooted devices with no modifications to system files.
    If you're not, post the full TWRP error message - it should say why it failed.
  12. MasterPoiuy
    No, I'm not rooted. But I have a custom recovery (TWRP).
  13. Spannaa
    KitKat Oct 27, 2017
    So, post the full TWRP error message!
  14. MasterPoiuy
    @Spannaa
    Code:
    I:eek:peration_start: 'Flashing'
    Installing zip file '/sdcard/Download/OnePlus2Oxygen_14_OTA_031-032_patch_1710240102.zip'
    Checking for MD5 file...
    Skipping MD5 check: no MD5 file found
    I:Update binary zip
    I:Zip does not contain SELinux file_contexts file in its root.
    I:Legacy property environment initialized.
    Verifying current system...
    contents of partition "/dev/block/bootdevice/by-name/boot" didn't match EMMC:/dev/block/bootdevice/by-name/boot:12375336:032952f3ae8a27b309907e2ac9ad6f359b63ece6:12375336:ae8f50c4c1d93388a8136153765c6aa4f44dba54
    file "EMMC:/dev/block/bootdevice/by-name/boot:12375336:032952f3ae8a27b309907e2ac9ad6f359b63ece6:12375336:ae8f50c4c1d93388a8136153765c6aa4f44dba54" doesn't have any of expected sha1 sums; checking cache
    failed to stat "/cache/saved.file": No such file or directory
    failed to load cache file
    script aborted: "EMMC:/dev/block/bootdevice/by-name/boot:12375336:032952f3ae8a27b309907e2ac9ad6f359b63ece6:12375336:ae8f50c4c1d93388a8136153765c6aa4f44dba54" has unexpected contents.
    Updater process ended with ERROR: 7
    I:Legacy property environment disabled.
    I:Install took 27 second(s).
    Error installing zip file '/sdcard/Download/OnePlus2Oxygen_14_OTA_031-032_patch_1710240102.zip'
    Updating partition details...
    I:Data backup size is 10697MB, free: 35032MB.
    I:Unable to mount '/usbstorage'
    I:Actual block device: '', current file system: 'vfat'
    ...done
    I:Set page: 'flash_done'
    I:eek:peration_end - status=1
    I:Set page: 'clear_vars'
    I:Set page: 'install'
    I:Set page: 'main'
    I:Set page: 'main2'
    I:Set page: 'advanced'
    I:Set page: 'copylog'
    I:Set page: 'action_page'
    I:eek:peration_start: 'Copy Log'
    I:Copying file /tmp/recovery.log to /data/media/0/recovery.log
  15. MasterPoiuy
    Error log posted above ^^^ please suggest if you have any solutions. Thanks.
  16. Titokhan
    Honeycomb Oct 28, 2017
    MasterPoiuy and Spannaa like this.
  17. Spannaa
    KitKat Oct 28, 2017
    Spannaa , Oct 28, 2017 :
    It says your boot partition (kernel) isn't fully stock so the update aborted.
    The solution is to flash the full 3.6.1 zip.
    EDIT: Ninjad by @Titokhan!
    Titokhan and MasterPoiuy like this.
  18. kaihp
    Jelly Bean Oct 28, 2017
    kaihp , Oct 28, 2017 :
    Okay, I've made an arse of myself and overwritten the boot flash partition.
    I was on TWRP-3.1.0 & OOS 3.6.0, working to upgrade to 3.1.1/3.6.1 and simply by not paying enough attention to reusing the "fastboot flash recovery twrp-3.1.1.0-oneplus2.img" line, I manage to flash twrp to the boot partition as well: "fastboot flash boot twrp-3.1.1.0-oneplus2.img" (note the flash that shouldn't be there :confused:). I found the Stock OnePlus2 Toolbox.zip and flashed boot1.img to the phone.
    I can boot into fastboot & recovery (TWRP 3.1.1) without problems, but booting into the system is hosed. I have the 3.6.1 full zip on the phone - can I just install that and it'll overwrite the boot partition?
    Edit:
    Solved it. I extracted the boot.img from the 3.6.0 full zip and flashed that. Then it would boot normally. I presume that flashing the full 3.6.1 zip would have solved it as well.
  19. Spannaa
    KitKat Oct 29, 2017
    Spannaa , Oct 29, 2017 :
    Yep, that would have sorted it.
    kaihp likes this.
  20. Fludizz
    Donut Oct 31, 2017
    Fludizz , Oct 31, 2017 :
    Looks like hell has frozen over after all! I got the OTA notification today. Been so long since the last update that I didn't recognize the notification icon anymore at first LOL. The best part, it also includes the Android security patch up to October, meaning the Bluetooth vulnerability is also fixed!
    Will sideload the Update zip as OTA doesn't appear to work on fully encrypted phones.
    edit: sideloading worked like a charm :)
    kaihp, Rusty NZ and Spannaa like this.
