13
OxygenOS Missing features
  1. G_Lukáš_Biel_Bbkz
    Donut May 28, 2018
    G_Lukáš_Biel_Bbkz , May 28, 2018 :
    Dear OnePlus, please add these features:
    1) Make top corners (in non-fullscreen apps or hidden notch) rounded with same diameter like the bottom ones to make phone display look symmetrical
    2) Add fingerprint gestures to roll down the statusbar - really needful on display this huge
    3) More accent colors, provided ones are ugly :-/
    4) AOD
    5) Battery percentage (I know this one is comming)
    6) Date in extended statusbar clickable to CALENDAR and clock to clock app (now date leads to clock app and clock are not clickable)
    Thank you
  2. infide1
    Donut May 28, 2018
  3. manuel19
    KitKat May 28, 2018
    manuel19 , May 28, 2018 :
    1) I think they're actually working on this
    2) this won't come as OnePlus said it isn't possible to make this work consistently
    3) they said a long time ago that they're experimenting with a RGB wheel and changes will come soon[e]2122[/e]
    4) I don't know but I think it will come back, as it seems to be there right now but not visible
    FlixbusLennart likes this.
  4. bord
    Gingerbread May 28, 2018
    bord , May 28, 2018 :
    8) Double tap to sleep
  5. GeertBerkers
    Lollipop May 28, 2018
    GeertBerkers , May 28, 2018 :
    Use fingerprint or face unlock to change Lock screen settings. Now we have to insert our pin/password/pattern.
    When I used the 3T, I just could use fingerprint to change these settings.
    Option to set time at the right side of the statusbar.
    And maybe bluetooth and other icons left
  6. manuel19
    KitKat May 28, 2018
    launcher settings? should be available already
    It's now to have better security. fingerprint is not 100% secure, faceunlock even less. your pin/password/pattern should be 100% secure
  7. bord
    Yes you're right. Didn't notice yet :)
  8. DionScheepmaker
    Donut May 28, 2018
    DionScheepmaker , May 28, 2018 :
    9) The option to hide apps in the app-drawer, like in Nova Launcher. I really like the stock launcher, but this is the only feature I really miss from a third party launcher.
    Corbalan likes this.
  9. nishant55555
    Cupcake May 28, 2018
    sppssk likes this.
  10. Bart_NL
    vishnujayapal likes this.
  11. Arihantsaini
    Arihantsaini , May 28, 2018 :
    its already available
    long press on home screen
    go to home settings
    and there u go bro... [e]1f609[/e]
  12. manuel19
    KitKat May 28, 2018
    don't know if it's available for op6, but for op5/t and 3/t it is, in the app drawer, pull from the left corner and you have a hidden space. So it'll come to the op6 very soon if it's not available already
  13. DionScheepmaker
    Donut May 28, 2018
    I can't seem to pull anything from the left corner.. Maybe it'll come to the OP6 later.
  14. GeertBerkers
    Yeah, because no one watches my pattern or pin. Nothing is 100% secure...
  15. manuel19
    KitKat May 28, 2018
    Then I think it should come within the next 1 or 2 updates
    DionScheepmaker likes this.
  16. manuel19
    KitKat May 28, 2018
    That's the dumbest thing I've ever read. Just make a password that's safe enough and keep it for you. How is that not 100% secure?
    If your request would get accepted (what will never happen), anybody who got a similar facial construction, or with an fingerprint who's able to trick your fingerprint scanner, could not only get into your phone, but also change your security settings, to log you out from your own device. What's completely stupid, if you think of it.
  17. lutti
    KitKat May 28, 2018
    lutti , May 28, 2018 :
    Why would you do that? First you would install an app and then you would remove a way to launch it? How about just uninstalling it if you don't want it there?
  18. DionScheepmaker
    Donut May 28, 2018
    Because I like having shortcuts of certain apps I use the most on my home screen. And having the same apps standing in the drawer, making the list longer than it has to be, doesn't make sense to me. So I like to hide the double ones.
  19. J1527327662573
  20. DanielPT
    Donut May 28, 2018
    DanielPT , May 28, 2018 :
    Can somebody tell me if there is eney gestures with the fingerprint scanner? Like turning the flash light on? :) Thanks.
