13
OxygenOS Missing features
  1. lutti
    KitKat May 28, 2018
    lutti , May 28, 2018 :
    Well that sort of makes sense. I use only few from the home screen so i never thought of this scenario to be an issue.
  2. GeertBerkers
    Lollipop May 28, 2018
    GeertBerkers , May 28, 2018 :
    Yeah right. They can hack my DNA, but not a pattern or pin
  3. manuel19
    KitKat May 28, 2018
    manuel19 , May 28, 2018 :
    the method proving your biometrics don't need to be a 100% match. it's just a percentage where the algorithm thinks it's the right. For example, Touch ID has a fail rate of 1/50.000 of a finger recognized as another person's finger. Face ID in comparison has 1/1.000.000 . Considering there's more than 7 billion people on earth, it's very high for someone to unlock your phone.
    Even if it probably won't happen, the chance still exists.
    Anyways: as apples touch ID is far slower, I don't think that the % recuired for oneplus' fingerprint is as high, and therefore not as secure, because apple is security over speed at that point. also OnePlus face unlock is even less secure than fingerprint, even if the algorithm is really stunning. It's even mentioned by OnePlus and that's why you're not able to secure your apps with faceunlock for example.
    Nobody can trick your code by typing a code that's similar to yours, but with biometrics, similar biometric patterns are likely to unlock your device. Therefore, they're by far not secure as a password.
    Also, biometrics are actually very bad to lock something. If you lose them, for example if anybody has your biometrics, you're lost. You can't change your fingerprint. If you lose your pin, you can just change it. Sure, that sounds dumb. But I am almost sure the FBI etc has access to your (even if they should be secured) biometrics, and there would be a leak or whatever of your fingerprints, they're lost.
    I hope this lightened things up for you.
  4. E1527535581613
    Cupcake May 28, 2018
    E1527535581613 , May 28, 2018 :
    ▪️folders in app draw
    ▪️bring back fingerprint gestures for OnePlus 6
    ▪️ notification numbers instead of dots, I wanna see how many unread messages I have
    ▪️for the OnePlus 6 the ability to put things like battery, WiFi and signal to the left of the notch
    ▪️a Easter way to optimise apps to full screen for the OnePlus 6 as some apps you think .... of I've not full screened this app yet...... home-setting-display-scroll,scroll ah that app full screen..... back to what I was doing now
  5. Sandeep_Thakkar
  6. malidan
    Marshmallow May 28, 2018
    malidan , May 28, 2018 :
    Scramble your pin, that is assuming the option is in OOS.
  7. malidan
    This you will not see, there is alot more to AOD than you think, from your comment.
  8. manuel19
    KitKat May 28, 2018
    Or do it like me, 16 digit password and unlock just by biometrics, so noone will see it :)
  9. manuel19
    KitKat May 28, 2018
    Sure there's more to it. But I am almost sure it'll come back. we'll see
  10. malidan
    Comeback? OP have never had AOD.
    It will be too much work for OP to apply it properly.
  11. manuel19
    KitKat May 28, 2018
    uhm, excuse me? it already has been in the OOS version the op6 ships with, but got removed in the first update, because it has bad impacts on the battery life, as OnePlus mentioned.
    So they most likely be tweaking it now and bring it back then. It already has everything. deactivates after a while when in a pocket, pixel shift to prevent burn-in.. Don't know what OP would still need to 'apply it properly'
  12. malidan
    Marshmallow May 30, 2018
    malidan , May 30, 2018 :
    Interesting as it wasn't mentioned in any review, only the ambient display.
  13. NatashaSehgal
    Cupcake May 30, 2018
    NatashaSehgal , May 30, 2018 :
    - Option to select all in the gallery (everything or all on a particular day) rather than selecting images one by one.
    - Option to view all images in the gallery and not just sorted by collections or photos (taken on the phone)
    Arthur_coudron likes this.
  14. manuel19
    KitKat May 30, 2018
  15. Medxion007
    Donut May 30, 2018
    Medxion007 , May 30, 2018 :
    Would be nice if they enable the phone speaker when watching video's. Did made some phonecalls on speaker and i think a Stereo feature would be nice :).
    nishant55555 likes this.
  16. bighead85
    Cupcake May 31, 2018
    bighead85 , May 31, 2018 :
    I have always used custom ROMs on my previous Oneplus devices and for me the stand out missing feature is long press power button with screen off for Torch. I know i can do gestures but they are not as good and easy to do by mistake (changed mine to W for now to make it less easy to do by mistake). One handed simple torch as you pull out of pocket was perfect, however I like most other features so was not going to go with a Custom ROM this time.
  17. FlixbusLennart
    The Lab - OnePlus 6 Reviewer May 31, 2018
  18. Linxx
    Froyo May 31, 2018
    Linxx , May 31, 2018 :
    I wholly endorse #1 and #6. These missing features need to be addressed quickly by OnePlus
    #38
  19. quini
    Eclair Jun 1, 2018
    quini , Jun 1, 2018 :
    11) Split ringtone and notifications volumes,
    12) Add 16:9 aspect ratio to rear camera
    #39
  20. lutti
    KitKat Jun 1, 2018
    lutti , Jun 1, 2018 :
    This! I have no idea why this hasn't been an option from day one.
    #40
