14
ROM MIUI 6 Port
  1. dhruvinvitsu
    Cupcake Aug 27, 2015
  2. itsmetgs
    Gingerbread Aug 27, 2015
  3. faizul2009
    faizul2009 , Aug 27, 2015 :
    save the number with countrycode
    viruz1225 likes this.
  4. Woodby
    Froyo Aug 27, 2015
    Woodby , Aug 27, 2015 :
    I genuinely don't think the OnePlusTwo exists and that we're all stuck in a Matrix...
  5. BlackReb
    BlackReb , Aug 27, 2015 :
    Hello, I have flashed MIUI 5.8.21 by X_s and i've received 5.8.27 OTA. But when I try to update, TWRP gives me an error and doesn't update :/ Can someone help me please? Thanks :)
  6. gagan3421
    relic242 likes this.
  7. gagan3421
  8. kevalthakkar20
    kevalthakkar20 , Aug 27, 2015 :
    Link plz
  9. BlackReb
  10. faizul2009
    Cupcake Aug 28, 2015
    faizul2009 , Aug 28, 2015 :
    I found TWRP gives error about patching provision.apk. & it doesn't exist in /system/app.
    So I extract the OTA zip & delete the provision.apk patching line from updater script. Then rezip again & flash via twrp. :)
  11. itsmetgs
    Gingerbread Aug 28, 2015
    itsmetgs , Aug 28, 2015 :
    Can you provide the exact line to remove from the updater script. Coz i found three line containing provision.apk?
  12. itsmetgs
  13. Errol Martin D'mello
    Honeycomb Aug 28, 2015
  14. crimsonm
  15. faizul2009
    I have already removed those lines. So I am showing you similar line: You will find like this
    Code:
    set_progress(0.020394);
    assert(apply_patch_check("/system/app/provision.apk", "3cca4ffddd1adb60597c1e0be6212d034149c3b6", "d7a5f98901ace602c8ff4662bdcd2953b7ceabcf"));
  16. itsmetgs
    Thanks. I will try.
  17. kevalthakkar20
  18. KforHorizon
    KitKat Aug 28, 2015
  19. shijopj2014
    shijopj2014 , Aug 28, 2015 :
    Hi... anyone tried the latest update of x_s version 5.8.27...?? G apps working with it? Which gapps should use with it? 4.4 otr 5.1 gapps... I think it is MIUI7 and 5.1 gapps should be flashed. Please confirm... thanks
  20. gagan3421
    shijopj2014 likes this.
