2
MMS Issues
  1. N1568815488114
    Cupcake Jan 16, 2020
    N1568815488114 , Jan 16, 2020 :
    Has anyone else on VZW not been able to receive MMS messages since the OxygenOS 10 update? VZW has said it's a device issue, not a network issue and I don't know what to do. Help please!! I've already restarted my phone, cleared the partition cache, moved my sim card to the other slot, reset my network connection.
    jriley17 and L1543109337666 like this.
  2. MSOE_NGINEER
    Eclair Jan 19, 2020
    MSOE_NGINEER , Jan 19, 2020 :
    The only fix, atm, is to replace the sim card with a new one. I am not sure what the underlying issue is, but it's a PITA nonetheless- especially if you run open beta and do the "monthly" updates. The last two open beta's and a10 have broken MMS. The only other solution is to use the one plus messages app and no other app.
  3. L1543109337666
    Cupcake Jan 23, 2020
    L1543109337666 , Jan 23, 2020 :
    I'm having the same issue. After the update to Android 10 and OxygenOS version 10.3.0 on my OnePlus 6T, I no longer receive MMS messages (group messages or picture messages). I called OnePlus technical support on 1/6/2020, they said that it was a known issue and that their developer was working on a fix that should be released in one week. It's been 2.5 weeks and still nothing. OnePlus technical support said that the only other option was to roll back to Android 9, which requires you to plug your phone into a computer and then have a customer support representative remotely log into your computer and perform the roll back. NOT something I want to do. Where is the fix?
  4. Caoimhín
    OnePlus 9 Series Expert Community Expert Jan 23, 2020
    Caoimhín , via OnePlus 6T , Jan 23, 2020 :
    Install latest OOS 10.3.1 just released, it is a Staged Rollout, so if you don't see it via OTA, you may need to do it via 3rd party app Oxygen Updater from the Playstore, see if it fixes the issues
  5. MSOE_NGINEER
    Eclair Jan 27, 2020
    MSOE_NGINEER , Jan 27, 2020 :
    Did this fix the MMS issue, or are you just recommending this update hoping it might fix our issue?
  6. S1542634049700
    Cupcake Jan 27, 2020
    S1542634049700 , Jan 27, 2020 :
    I updated from 10.3 TO 10.3.1 and THEN started experiencing this issue as everyone else describes on my 6t
    A1541469474900 likes this.
  7. L1543109337666
    Cupcake Jan 28, 2020
    L1543109337666 , via OnePlus 6T , Jan 28, 2020 :
    I couldn't wait any longer for the OTA update to arrive. So I hesitantly updated to OxygenOS 10.3.1 via the Oxygen Updated app. The update solved my MMS receiving issue!
    It also solved another issue. After updating to Android 10, my "Commute to home" routine with the Google Assistant quit working. I have the routine set to send a text message to my wife along with a couple other tasks. After the Android 10 (and OxygenOS 10.3.0) update, the routine would always fail at the point where the Google Assistant tried to send the text message, saying something along the lines of, "Actually, I can't do that." After the OxygenOS 10.3.1 update, this routine is working again!
  8. R1562010951696
    Eclair Mar 22, 2020
  9. MSOE_NGINEER
    Eclair Mar 23, 2020
    MSOE_NGINEER , Mar 23, 2020 :
    well, after being on the OB5 installed on 2/19, MMS broke again (after being ok for a month). All Verizon stores are closed to boot, so no replacement sim now either...FML maybe OB6 will fix this again?
  10. Caoimhín
    OnePlus 9 Series Expert Community Expert Mar 23, 2020
    Caoimhín , via OnePlus 6T , Mar 23, 2020 :
    Not sure if it can help, but you can upgrade to 10.3.2 Stable build, as it is a newer build it will install without data loss, even though it gives a warning that it will. That's because you are upgrading from one build to another.
    If you want to try that go to the OnePlus support link below, choose your phone model, download 10.3.2 Stable build and install, following the instructions on the website.
    https://www.oneplus.com/support/softwareupgrade
  11. MSOE_NGINEER
    Eclair Mar 23, 2020
    updated to regular 10.3.2, now a whole bunch of other issues cropped up with photos and Google voice... FML.....I knew I shouldn't but did anyway....now I have to wait for OB6 and can't use my phone for pictures.... so angry!
  12. Caoimhín
    MSOE_NGINEER
    updated to regular 10.3.2, now a whole bunch of other issues cropped up with photos and Google voice... FML.....I knew I shouldn't but did anyway....now I have to wait for OB6 and can't use my phone for pictures.... so angry!​
    Pictures should be fine, update the Gallery App in the Play store if available, check the OnePlus statement below. It can take a few hours for the OnePlus Gallery to update itself with photos.
    Also Google Photos should display them fine.
    https://forums.oneplus.com/threads/...disappearance-problem-in-gallery-app.1164151/
    It can take a while for some of the Google apps to function correctly, as it does its updates. Usually the Playstore, Play services etc.
    Go through a couple of full drain and charge cycles, usually fixes most glitches.
  13. MSOE_NGINEER
    Eclair Mar 23, 2020
    everything is crashing..... FML... I'm so mad at you and myself for being so dumb..... I knew better and still did it being naive....
    already did a clear cache from the bootmenu (Power button and volume down during boot)
    Also did Clear the App info Cache and App info Storage for all 4 items
    Google Playstore
    Google Play services
    Google Services Framework (Search in Setting for this)
    Google App
    Restarted the phone several times.
  14. pfvatterott
    Cupcake Mar 24, 2020
    pfvatterott , Mar 24, 2020 :
    Have you found a solution? The same thing has happened to me.
  15. MSOE_NGINEER
    Eclair Mar 24, 2020
    MSOE_NGINEER , via OnePlus 6T , Mar 24, 2020 :
    I had to factory reset.
    mms issues still exists post factory reset... something in the new releases of messages caused this to happen.
    at this point I'm kind of giving up on this... I'll wait for open beta 6 to come out. if that doesn't fix the MMS issue, then I will opt for a new SIM card. But that too will likely be short-lived based on past performance thus far.
  16. adashofhope
    Cupcake May 28, 2020
    adashofhope , May 28, 2020 :
    Having MMS issues creating group chats with everyone on my phone plan. I can receive and send messages to other groups. if I try to create a MMS group with the folks on my plan--. I either automatically get "you have left the chat" or "sending aborted, try again".
    So far I am the only one on my phone plan that can not create a group chat using the already installed messaging app.
    Any idea what may be the issue... Called OnePlus tech support, and have been waiting for about an hour each time I call-- not much help there. (still waiting again while typing this out)
  17. R1562010951696
    Eclair May 30, 2020
  18. Caoimhín
    OnePlus 9 Series Expert Community Expert May 30, 2020
    Caoimhín , via OnePlus 6T , May 30, 2020 :
    contact OnePlus support Online Chat directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
  19. J1576224894122
    Cupcake Aug 12, 2020
    J1576224894122 , Aug 12, 2020 :
    I currently have Oxygen OS version 10.3.5 on my Oneplus 6t and am unable to send mms text messages. Has anyone found a reliable fix that doesn't cause other problems once you apply it? I was hoping over time Oneplus would have fixed it as suggested in this thread. Thanks in advance for any help.
  20. Caoimhín
    OnePlus 9 Series Expert Community Expert Aug 12, 2020
    Caoimhín , via OnePlus 6T , Aug 12, 2020 :
    Have no issue with sending MMS myself, make sure you Mobile Carrier APN is set correctly. I also use Google Messages to send and receive MMS.
    Also check with your Mobile Carrier that there are no issues on their end with your Network profile.
