MMS not sending
  1. G_Danial_Javaheri_FOSE
    Donut Mar 22, 2017
    G_Danial_Javaheri_FOSE , Mar 22, 2017 :
    Hi guys.
    I can't get any MMS. I've talked to my operator (Tele2 Sweden) and I've manually set the settings. Still no MMS.
    Any tips?
  2. G_Danial_Javaheri_FOSE
    Donut Mar 23, 2017
  3. MatteHD
    Cupcake Mar 23, 2017
    MatteHD , Mar 23, 2017 :
    Data is working ?
    On the apn settings you set manually the apn for mms talking with your carrier ? The setting should be like this:
    APN: 4G.tele2.se
    MMSC: http://mmsc.tele2.se
    MMS Proxy: 130.244.202.30
    MMS Port: 8080
    Authentication type: PAP
    APN type: mms
    meatandy likes this.
  4. meatandy
    Oreo Mar 23, 2017
    meatandy , Mar 23, 2017 :
    Is the MMS box checked?
    MatteHD likes this.
  5. G_Danial_Javaheri_FOSE
    Donut Mar 24, 2017
    G_Danial_Javaheri_FOSE , Mar 24, 2017 :
    Data is working. An I just copy pasted all your preferences. Still no work :(
  6. MatteHD
    Cupcake Mar 24, 2017
    MatteHD , Mar 24, 2017 :
    So you should have:
    1 apn for data checked
    2 apn for MMS
    Try to remove the authentication type from the settings so:
    APN: 4G.tele2.se
    Proxy MMS: 130.244.202.30
    Port MMS: 8080
    Authentication type: not set
    APN type: mms
    Save and try again to send it. Delete all outgoing mms and try from new one.
  7. G_Danial_Javaheri_FOSE
    Donut Mar 26, 2017
    G_Danial_Javaheri_FOSE , Mar 26, 2017 :
    Okeey dude. Strangest thing just happened . I Did turn off the authentication and send my MMS to myself. And it arrived.
    HOWEVER I just wanted to try again and turned off the WiFi and it didn't go through.
    I have tried 6 times with and w/o wifi.
    I don't get the MMS if I'm not connected to the WiFi
  8. Kirakichi
    Jelly Bean Mar 26, 2017
    Kirakichi , Mar 26, 2017 :
    Wierd, it uses phone data to send data, not wifi.
    On Vimla operator (virtual operator of Telenor SE) i had to manually put in MMS settings to my APN, it worked after that.
    Make sure you really type it correct every part, everything! It is APN misconfiguration most likely.
  9. MatteHD
    Cupcake Mar 28, 2017
    MatteHD , Mar 28, 2017 :
    yeah its weird , cuz MMS usually require an exchange of packet data and can work with wifi just if the carrier support wifi calling. Can you share screen with your apn setup :
    1 screen with details of apn data
    2 screen with details of apn mms
    3 screen apn list
  10. G_Danial_Javaheri_FOSE
    Donut Mar 30, 2017
    G_Danial_Javaheri_FOSE , Mar 30, 2017 :
  11. MatteHD
    Cupcake Mar 31, 2017
    MatteHD , Mar 31, 2017 :
    I Tried to search on your carrier website , it report another proxy lets Try:
    APN: 4G.tele2.se
    Proxy MMS: mmsproxy.tele2.se
    Port MMS: 8080
    APN type: mms
    the proxy is in a 90.X.X.X netrange so it should be a different one Try it. When you can share also the screen of the settings of data apn.
  12. G_Danial_Javaheri_FOSE
    Donut Mar 31, 2017
    G_Danial_Javaheri_FOSE , Mar 31, 2017 :
    Did change it. Still nothing. :(
  13. andolfino79
    Cupcake Apr 18, 2017
    andolfino79 , Apr 18, 2017 :
    APN: 4g.tele2.se
    Port MMS: 8080
    APN type: default,supl,mms
    Then delete all the other APN. Works for me :) (Tele2).
  14. G_Danial_Javaheri_FOSE
    Donut Apr 19, 2017
    G_Danial_Javaheri_FOSE , Apr 19, 2017 :
    can you send a screenshot of your APNs and the APN settings. ty
  15. wenna
    Ice Cream Sandwich Apr 19, 2017
    wenna , Apr 19, 2017 :
    I had the same problem and my default APN was Telenor Mobilsurf. Manually choose Telenor SE instead and both data and MMS should work.
  16. andolfino79
    Cupcake Apr 19, 2017
    andolfino79 , Apr 19, 2017 :
  17. G_Danial_Javaheri_FOSE
    Donut Apr 20, 2017
  18. Kermit2
    Cupcake May 24, 2017
    Kermit2 , May 24, 2017 :
    Thank you!! This helped me to end a problem I have had since december/january. Tack så mycket :)
    wenna likes this.
  19. PanSzym
    Froyo May 24, 2017
  20. wenna
    Ice Cream Sandwich May 24, 2017
    wenna , May 24, 2017 :
    Varsågod [e]1f609[/e]
