Mobile connectivity issues via OnePlus 9
  1. NickDev
    Cupcake May 9, 2021
    NickDev , via OnePlus 9 , May 9, 2021 :
    Hi everyone!
    I've been using my Oneplus 9 since a week now and I'm experiencing bad connectivity issues.
    I use an Iliad sim and I previously used it in the Oneplus 6 without any problem at all.
    I was wondering if anybody has the same problem.
    Thank you for your time!
    J1618462878930 likes this.
  2. Swejuggalo
    OnePlus 9 Series Expert Community Expert May 9, 2021
    Best Answer
    Caoimhín and NickDev like this.
  3. NickDev
    Cupcake May 9, 2021
  4. Ghazala.Yasmeen
    OnePlus Bug Hunter Staff Member May 12, 2021
    Ghazala.Yasmeen , May 12, 2021 :
    We have got in touch with you through personal message, request you to check for the same.
    Regards,
    Ghazala
    NickDev likes this.
  5. #5
    NickDev likes this.
  6. NickDev
    Cupcake May 15, 2021
    NickDev , via OnePlus 9 , May 15, 2021 :
    As long as time passes, it's becoming more annoying.
    I often lose the connectivity even if I'm in the middle of the city, the only way to use internet connection in a stable way is to use WiFi.
  7. vinayvinayak62682
    Gingerbread May 15, 2021
    vinayvinayak62682 , via OnePlus 9 Pro , May 15, 2021 :
    I have a same issue so I just reset my network settings and Now it's working fine. Go to settings and then system ,reset options then reset wifi mobile and Bluetooth. enter password and you will not face problems .
    NickDev likes this.
  8. #8
