Mobile data exclamation point
  1. affec94
    Froyo May 14, 2017
    affec94 , May 14, 2017 :
    Hey guys I know that this thread was already posted in the past but I haven't been able to find a solution so here I go.
    In the last few weeks there has been an exclamation point near my 4g mobile data symbol. That being said WhatsApp and messenger usually work (like many apps that uses mobile data) but when I try to look something up on Google or when I try to visit a web page, it says that I'm not connected.
    I have tried to reset the network settings from the network and backup settings but nothing.
    Do you have any tips or solutions?? This is really annoying me.
    UPDATE:
    My SIM carrier is Tim (I'm Italian)
    I went to the apn settings and chose ibox.tim.it (TIM WEB) instead of the default wap.tim.it (WAP TIM)
    It seems to work fine now, still I don't know the difference between the two settings, care to explain to a noob like me?? xD
  2. affec94
    Froyo May 15, 2017
  3. carte004
    Cupcake May 15, 2017
    carte004 , May 15, 2017 :
    this is a strange one......usually an exclamation mark is only against the Wifi icon and thats an easy fix......sure its against the 4G icon?
  4. Ramdinpuia
    Honeycomb May 15, 2017
  5. Lancelot_69
    Lollipop May 15, 2017
    Lancelot_69 , May 15, 2017 :
    Try this
    Disable wifi and radio.
    Then settings - more - cellular network - preferred network - 3G
    Return to home screen, wait a minute while it connects up. When it connects the exclamation should be gone.
    Now go back and switch to 4G and it should connect again without exclamation
    W1576182233468 likes this.
  6. affec94
    Froyo May 15, 2017
  7. affec94
    Froyo May 15, 2017
    affec94 , May 15, 2017 :
    Just tried it but nothing :/
  8. milkdude
    KitKat May 15, 2017
    milkdude , May 15, 2017 :
    My best guess is power down your phone, pull your sim, then reinsert it.
    Then power it up.
    For whatever reason, it's not recognizing your service provider.
    S1589387027181 likes this.
  9. affec94
    Froyo May 15, 2017
    These are the errors I get when I try to go to a website with the 4g
    btw in the second screenshot the error is
    http/1.1 internal server error 43531
  10. Lancelot_69
    Should have maybe reboot phone after switching to 3g?
    Anyway you can try again what I suggested except reboot or you can try this.
    1. Add a new user
    2. Go ahead with the user setup
    3. When it's searching for networks shut down the power.
    = and after reboot the exclamation mark is gone
    Unfortunately lots of tricks are trial and error, if that doesn't work you can try other things like
    >First go to settings
    >Delete all apn Settings
    >Then go back to Settings >Mobile Network Settings >Access Point Names >Open the three dots on the right hand corner
    > Reset toDefault.
    All trial and error. Good luck
  11. affec94
    Froyo May 15, 2017
    Just tried it but no effect :(
    Any other guesses guys? Sorry if I am spamming your home feed
  12. affec94
    Froyo May 15, 2017
    Still nothing, but i guess i'll try thses tricks meanwhile
  13. affec94
    Froyo May 15, 2017
    UPDATE
    It seems to work still I don't know the difference between the two settings, care to explain to a noob like me xD
  14. saikiran4ever
    Jelly Bean May 15, 2017
    saikiran4ever , May 15, 2017 :
    First thing is : Our phones usually verify if we are connected to internet by making some ping requests to a predefined server (e.g. www.google.co.uk). If it's showing exclamation, it means you are not able to reach that server.
    Second thing is: You are saying that whatsapp is working fine. Some network providers provide free access to some websites though you haven't recharged with any data plan. This is called "free basics" by Facebook.
    So, check if you have any data plan active on your number or if there's anything is wrong with your mobile account by calling up the customer care.
  15. affec94
    Froyo May 15, 2017
    I see, since I do have a data plan I guess I'll call them to check up if anything is wrong, thanks for the tip
    saikiran4ever likes this.
  16. Lancelot_69
    Glad it's resolved
    affec94 likes this.
  17. mateisilviu
    Cupcake Oct 9, 2019
    mateisilviu , Oct 9, 2019 :
    Hello,
    I have the same issue on OnePlus 7.
    It worked ok for 1st 2 month since a have the phone but then suddenly I had exclamation mark.
    My carrier is Vodafone (Romania) and solution was to replace SIM card. But is strange that just today it happened again and I changed it last week.
  18. F_Constantin_Huidu_sral
    Cupcake Oct 22, 2019
    F_Constantin_Huidu_sral , Oct 22, 2019 :
    Hello,
    I also changed my Vodafone Romania SIM about 2 months ago due to issues with the network (same exclamation mark next to the 4G / 3G icon). Since then i had 2 more episodes. I didnt manage to find a fix after performing the following:
    - hard reset
    - installed a local betta OS
    - remote session with L2 OnePlus technician; a complete flush of the phone was performed.
    My 6T fully recovered by itself after approx 8 hours after the tech guy finished the reset - so the recovery had nothing to do with the intervention. I am sending the phone to service today and hoping i will get a different diagnosis and not "could not replicate".
    P.S. issue is not occuring if you use Orange Romania.
  19. N1572528618997
    Cupcake Oct 31, 2019
    N1572528618997 , Oct 31, 2019 :
    Hey gents, I'm in Canada. I have a 7 Pro and have the same issue consistently for the last week, I've replaced both my sim card multiple times to no avail. I'm on Bell's network they've been extremely helpful but are just as clueless as I am. I've tried everything suggested above to no avail as well. Any help would be appreciated.
  20. V1571407395944
    Cupcake Dec 10, 2019
    V1571407395944 , via OnePlus 7T , Dec 10, 2019 :
    I'm having this same issue I'm the US on Google Fi Network. I have found after restarting the phone a couple time it connects back up, I mainly have this problem if I go to an area with no service at all and try and reconnect such as a parking garage. currently trying switching my APN to only ipv4.
