mobile data is not working on Android 10
  1. abin_raju_001
    Cupcake Oct 17, 2019
    abin_raju_001 , Oct 17, 2019 :
    Mobile data is not working after new Android 10 upgrade.
    it can only work when reboot the device.
    After reboot if it turn off and turn on its not work.
    Each time need to reboot the device for mobile data work.
    Raghul Sripathy likes this.
  2. Raghul Sripathy
    Cupcake Oct 19, 2019
    Raghul Sripathy , Oct 19, 2019 :
    hi, please update your apn settings. I had this same issue, now it works completely fine post apn revision.
  3. abin_raju_001
    Cupcake Oct 27, 2019
    abin_raju_001 , Oct 27, 2019 :
    Raghul Sripathy
    hi, please update your apn settings. I had this same issue, now it works completely fine post apn revision.​
    it's not worked for me
  4. prfraczek
    Honeycomb Oct 27, 2019
    prfraczek , via OnePlus 7 Pro , Oct 27, 2019 :
    If you are in UK, three having problems no Internet on band 3. Install cell info app and check which band got no Internet. I believe after restart phone picking up different working band.
  5. mptpro
    Eclair Oct 30, 2019
    mptpro , Oct 30, 2019 :
    How do you update APN settings?
    OP7pro, Android 10, US, Tmobile
