11
Mobile Data Not Working.
  1. Mohakur
    Cupcake Oct 24, 2019
    Mohakur , via OnePlus 7 , Oct 24, 2019 :
    friends after the recent update 10.0.1 facing network issues like especially low speed internet and display brightness issue
    low speed cuz of no CA working properly after the update
    so again i went to previous version 9.5.2 now handset working fine
    may be it's a software bug allow some time developers will work on this
    KamalJat808 and M1558417504832 like this.
  2. JNiemi
    Gingerbread Oct 25, 2019
    JNiemi , Oct 25, 2019 :
    Use reset mobile, wifi and bluetooth
    Settings - System - Recovery options - Reset mobile, wifi...
    M1558417504832 likes this.
  3. M1558417504832
    Cupcake Oct 26, 2019
    KamalJat808 likes this.
  4. garyglc
    garyglc , via OnePlus 7 Pro , Oct 26, 2019 :
    I've had this problem since upgrading to Android 10. shows full signal but no pages load.
    games like clash of clans has constant issues with disconnecting.
  5. T1567083023942
    Cupcake Oct 27, 2019
    T1567083023942 , via OnePlus 7 , Oct 27, 2019 :
    similar issue here.
    All data connection lost, i.e. no 4g indicated.
    only way to restore is to activate airplane mode on & off.
    This was happening on Android 9.
    Worse on Android 10 beta
    Full reset back to 9, still happening
    Updated to Android 10 when released, still happening.
    very disappointed
    M1558417504832 and KamalJat808 like this.
  6. vjrana8164
    Donut Oct 30, 2019
    vjrana8164 , Oct 30, 2019 :
    Same here
  7. wted
    Cupcake Nov 1, 2019
    wted , Nov 1, 2019 :
    I am facing the exact same issue after upgrading to Oxygen 10.0.1, and I can only solve this by rebooting my phone as well...
  8. KamalJat808
    Eclair Nov 12, 2019
  9. Devd07
    Cupcake Nov 13, 2019
    Devd07 , Nov 13, 2019 :
    This is worst experience I have with any android mobile. Just after purchasing a brand new mobile, my mobile data is not working. I have to forcefully upgrade os from 9.5.5 which came as default while purchasing the mobile to Oxygen 10 as this is being quoted as one of the resolution from community. Usually, when you upgrade something, some issue comes in but this is very weird behaviour, brand new smart phone, data not working.
    OnePlus should seriously look into this before releasing or quoting so high price for mobiles with these blockers.
    Why customer should upgrade just after buying mobile on the very first day ??
  10. M1558417504832
    Cupcake Nov 18, 2019
  11. wted
    Cupcake Nov 19, 2019
    wted , Nov 19, 2019 :
    I tried this, doesn't work. Still need to enter airplane mode/rebooting the device to get LTE connection back. Pretty sure this is a software problem. I have never experienced this in Oxygen OS 9. After upgrading to OS 10 I face this issue almost everyday...
  12. H1571440624816
    Cupcake Dec 16, 2019
    H1571440624816 , Dec 16, 2019 :
    Has there been a solution to this? I've got a 7T Pro and from time to time the mobile data icon will just disappear above the reception bar. I either have to reboot or go into airplane mode to reset. Is this a software or hardware problem? I had this issue with my iPhone XS a while back and found that it was an issue with the modem they were using in the phone since some phones had Intel and others had Qualcomm (they were in a legal battle with Qualcomm at the time) which caused my phone to lose all reception and data. I'm hoping this isn't the case for the phone.
  13. Nestori Virta
    Cupcake Dec 17, 2019
    Nestori Virta , Dec 17, 2019 :
    Oneplus 7 Pro owner here. Same problem. I got the new OS update (10.0.3) 12h ago and this problem started. Is there anything that I can do? It is a pretty nasty issue especially in work environment.
    Thanks in advance
  14. A1576562932954
    A1576562932954 , Dec 17, 2019 :
    Same thing happened to me. Updated to 10.0.3 and mobile data stopped working. It's working in some apps like Instagram, Facebook and Youtube but Chrome, Google Play, and Spotify aren't working at all. It's really frustrating..
  15. Nestori Virta
    Yep exactly the same. Some apps work and then others don't. And for some reason the most important ones like email apps (Gmail & Outlook) and public transportation ticket won't just connect.
  16. S1511990488362
    S1511990488362 , Dec 17, 2019 :
    same problem here. now tried to reset the wifi bluetoot and mobile data settings hope it works
  17. Nestori Virta
    Found a workaround from reddit r/oneplus, worked for me.
    To anyone else still having the same problem. I got a finnish provider and its called DNA. So your results may vary depending on the provider.
    Here is what I did:
    Settings -> Sim-card & network -> pick the sim that is active -> Access point names -> pick the first one (x internet) x=provider -> APN and it was for me internet at first then I added .fi in the end. So Internet.fi in APN slot.
  18. nqd_reee19
    nqd_reee19 , Dec 17, 2019 :
    Nestori Virta you saved my day. It started this morning with my Oneplus 7T ( newest oxyxenOS ) and works fine with that "APN" internet.fi on DNA service provider.
    #38
    Nestori Virta likes this.
  19. nqd_reee19
  20. X1570617618748
    Cupcake Jan 1, 2020
    X1570617618748 , Jan 1, 2020 :
    at first I couldn't find the APN in the menu in place by other tutorial and blogs mentioned. you post helped to find this settings and I was able to manually create APN for my network. [e]1f44d[/e]
    #40
