mobile freezing and then display suddenly flickering and then off. via OnePlus 6T
  1. E1543701296572
    Cupcake Apr 10, 2020
    E1543701296572 , via OnePlus 6T , Apr 10, 2020 :
    my OnePlus 6t was suddenly freezed and display fully turned off and suddenly on.
    i didn't know what is problem going on in my mobile..
    pls someone give any suggestions..
    version 10.3.2
  2. Caomhin
    Lollipop Apr 10, 2020
    Caomhin , via OnePlus 6T , Apr 10, 2020 :
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
    E1543701296572 and drl431 like this.
  3. E1543701296572
    Cupcake Apr 23, 2020
    E1543701296572 , via OnePlus 6T , Apr 23, 2020 :
    Thank you..
    Caomhin likes this.
