Mobile kbi kbi rok jata he cemra block hi jata hr via OnePlus 7T
  1. #1
  2. NaXal
    Honeycomb Jun 11, 2021 at 6:10 AM
    NaXal , via OnePlus 8T , Jun 11, 2021 at 6:10 AM :
    Hello,
    Consider resetting the device to factory default.
    Start fresh after reset, avoid phone cloning or restoring system wide phone to phone backup, often this leads to copying of unwanted, unsupported, conflicting system apps & cause trouble in future.
    After setup is complete, check for updates, if any install them.
    Then visit play store & update all the apps
    Further, always use Play Store for installation of any apps. Avoid side loading any APK.
    Now check, if your device is performing as it should.
    Thanks.
