6
Mobile network standby drain battery
  1. official.suryakant
    Eclair Jun 17, 2019
    official.suryakant , Jun 17, 2019 :
    After update to Pie, Mobile Network Standby is draining way too much battery. I am getting 1.5 hours of screen on time, which used to be around 3.5 hours before the update. I am on Oxygen OS 9.0.3 stable for OnePlus 3T. Please have a look at the screenshot attached.
  2. uzerNAN
    Cupcake Jun 19, 2019
    uzerNAN , Jun 19, 2019 :
    Having same issue on my OnePlus 3T, I have recently updated to oxygenos 9.0.3 and the problem appeared.
    Tried to clear cache for all apps (one by one, so lame) and no change, battery is still draining like hell.
    The screenshot is attached.
    Any thoughts?
  3. Vipulnagekar
    Donut Jun 23, 2019
  4. G_Subrat_Nayak_eMEB
    Froyo Jun 29, 2019
    official.suryakant likes this.
  5. G_Subrat_Nayak_eMEB
    Froyo Jul 3, 2019
  6. Aziz_Amin_Oneplus
    Jelly Bean Jul 3, 2019
    Aziz_Amin_Oneplus , Jul 3, 2019 :
    Switch to 3G or 2G or close your 4g network on standby it will be back to normal.
  7. G_Subrat_Nayak_eMEB
    Froyo Jul 5, 2019
  8. G_Chris_Platt_gwvQ
    Cupcake Jul 5, 2019
    G_Chris_Platt_gwvQ , Jul 5, 2019 :
    I'm having the same issue. Happened as soon as I updated to pie 9.0.3
    The drain is almost acceptable when i'm connected to wifi, when i'm off wifi its 2% an hour minimum. Ruled out low reception because i'm in a high reception area and never had this issue before updating to 9.0.3
    Considering I haven't changed my carrier, location or habits it can only be a firmware issue.
    Despite that, i've tried:
    Factory reset
    Turning off wifi and bluetooth scanning
    data saver
    battery saver
    disabling VoLTE
    safe mode - to rule out 3rd party apps
    disabling google play services from using background data
    Using 3G only
    Trying different preferred networks in the *#*#4636#*#* menu
    uzerNAN and official.suryakant like this.
  9. official.suryakant
    Eclair Jul 8, 2019
    official.suryakant , Jul 8, 2019 :
    If you use Jio than there is no 3G or 2G network. Jio only operates on 4G.
  10. angelantonio92
    Cupcake Jul 20, 2019
  11. Bolsdera
    Cupcake Aug 4, 2019
    Bolsdera , Aug 4, 2019 :
    Hi. Personaly, i roll back to oxygenos 5.0 and return to 9.0 if, one day, there is a patch... It's so a big bug, too bad.
    uzerNAN likes this.
  12. DevineMortal
    Eclair Sep 24, 2019
    DevineMortal , Sep 24, 2019 :
    Same issue here. Battery drain is way too much by "Mobile Network Standby". I thought OnePlus listens to feedback of users or is it that OP3 users are not important anymore!?
    uzerNAN likes this.
  13. F1569871474281
    Cupcake Oct 2, 2019
  14. Vijay_Manohar
    Cupcake Oct 3, 2019
    Vijay_Manohar , Oct 3, 2019 :
    i had the same issue may be bcuz android pie is heavy, had flashed stable version of oxygen os 9.0.2 and issue persisted from oneplus spprt, Now have downgraded back to android 8, issue is somewhat ok now with minor bttry drain as android 8 is much lighter to heavier android versions that are coming through.
  15. dobridin
    Eclair Oct 9, 2019
    dobridin , Oct 9, 2019 :
    Hello, I have the same issue here. My battery drain is 50% due to the radio signal. I was hoping that new update can fix the issue but it seems that there is no update coming at all. It starts to smell like this was made on purpose for us to change our phones with a newer model.
  16. zdravco
    Cupcake Oct 14, 2019
    zdravco , Oct 14, 2019 :
    Hi all. I am facing the same issue here, though I think it didn't start immediatelly after the update (maybe I didn't notice it right away).
    Is there a fix here?
    Does anybody know if this is a bug or simply goes like this with this combination of phone/os?
    Does downgrading to android 8 help at all?
  17. abeeypal
    Cupcake Dec 24, 2019
    abeeypal , Dec 24, 2019 :
    @OnePlus team,
    This issues is ongoing since June 2019. I just updated my 3T to 9.0.6 few days back and facing the same issue ever since.
    Is someone even looking into this or this forum is created up just for the sake of it?? Now I have to carry a power bank with me all day long.
    Your users need a fix to this problem.
    Simple logic - What is the use of adding new features for making the phone look shinier and feature packed if there is no battery for it to run on??
    @David Y. Adding David so that this issue is raised with the respective team.
  18. R1582192026409
    Cupcake Feb 20, 2020
    R1582192026409 , Feb 20, 2020 :
    Hey yall. New here dont have a oneplus but researching the same issue....can anyone try going into developer mode and look for mobile data always active..... If its on try switching it off, and if its off toggle it a couple of times and power cycle your phone or soft reset.... Hope that helps. Thanks
  19. Kapilbhola
    Donut Feb 25, 2020
    Kapilbhola , Feb 25, 2020 :
    Hello David,
    What is the latest progress on this issue please if you can help?
  20. kanirudha14
    Cupcake Mar 9, 2020
