3
Mobile Radio Active Bug (Battery Drain)
  1. ruggerxpunk
    Froyo Apr 15, 2015
  2. shawnc
    Gingerbread Apr 15, 2015
    shawnc , Apr 15, 2015 :
    Even i just noticed that my mobile radio has been using alot of battery.
    Maybe cyanogen has to push another update to fix this issue
  3. ruggerxpunk
    Froyo Apr 15, 2015
    ruggerxpunk , Apr 15, 2015 :
    Unfortunately based on that XDA article, this issue persists even into Android 5.1
    I'm getting tired of these Android Only types of issues...
    LEXXIUS and 0verlord like this.
  4. Jac_Q
    Ice Cream Sandwich Apr 15, 2015
    Jac_Q , Apr 15, 2015 :
    Android L is the worst thing ever happened to Android.
    There are millions of bugs waiting to kill your battery and/or nerves.
    Just a few examples:
    - RAM drain
    - Mobile Radio active bug
    - Exchange Services not working properly
    - Bluetooth problems
    And these are just a few examples.
    Google really did a lousy job here.
    mugioh, Ascaban04, LEXXIUS and 4 others like this.
  5. carl2210
    Honeycomb Apr 18, 2015
    carl2210 , Apr 18, 2015 :
    I have same issue but on oxygen. The main ones are gmail, google service and google app that have like close to 3hr of mobile radio active consumption. I'm sure that eats up some juice. I don't seem to suffer from wakelock as much as others. Any progress on this?
  6. jeffery
    Gingerbread Apr 18, 2015
    jeffery , Apr 18, 2015 :
    Google provides free bug, Cyanogen multiply the bugs, so we are just bug farmers.:eek::eek::eek::eek::eek::eek::eek:
    Takendown, taka61, jaferiqbal and 9 others like this.
  7. shrubber
    Gingerbread Apr 21, 2015
    shrubber , Apr 21, 2015 :
    Same problem here. No wakelocks and deep sleep works great. The only thing you can do is to kill app that drain the battery because their use of mobile radio and prevent those app to restart with privacy guard...
    With this technique I have reached a drain of 3,5% per hour that is not so bad...
    Another thing you can do is to stay under WiFi as most as you can... No drain here...
    And wait for a bug fix... But don't expect early...
  8. shrubber
  9. byordanov88
    Donut Apr 22, 2015
    byordanov88 , Apr 22, 2015 :
    does everybody have the issue or is it just a few of us, because there is not a lot of talking about this and nobody is giving a solution
  10. kansleri
    Eclair Apr 22, 2015
    kansleri , Apr 22, 2015 :
    I have this problem. Battery stats shows Chrome as the most power hungry.
    SyCzx likes this.
  11. radocernak
    Gingerbread Apr 23, 2015
  12. davediced
    Cupcake Apr 24, 2015
    davediced , Apr 24, 2015 :
    yep, i get this. at least 1hr + mobile radio active for every app that was opened in the day. With only 1hr 12min screen on time and im down to 55% battery !!
  13. Joonas
    Honeycomb Apr 24, 2015
    Joonas , Apr 24, 2015 :
    Same here. I feel like 3G is using more battery than before and this explains it
  14. ahighfield
    KitKat Apr 24, 2015
    ahighfield , Apr 24, 2015 :
    Wherever you are you seem to have terrible cell reception...
    Nevertheless...I have this problem also anyway, 3hrs SOT only for full charge down to 15% yesterday and many apps showing hours of mobile radio active for only 5mins of foreground activity...
  15. tim440
    Cupcake Apr 25, 2015
  16. Agnus
    Cupcake Apr 26, 2015
  17. gigs
    Ice Cream Sandwich Apr 26, 2015
  18. imam subadi
    Gingerbread Apr 27, 2015
  19. Agnus
    Cupcake Apr 27, 2015
  20. rhumagricole
    Ice Cream Sandwich Apr 27, 2015
