11
[MODDING] All about Rooting & Recovery
  1. weikang2753
    KitKat May 18, 2015
    weikang2753 , May 18, 2015 :
    try plug to others computer and try again. if detected, then consider reinstall your Windows.
  2. Firdaus915
    Cupcake Jun 1, 2015
  3. nujteel
    Cupcake Jun 18, 2015
    nujteel , Jun 18, 2015 :
    Hello OPO sis and bro,
    I am on CM11 SNAPSHOT M11 bacon now. I would to upgrade it to CM 12.
    How can I go about it? Appreciate your guidance on that. Thanks. :)
  4. gabwst17
    Gingerbread Aug 18, 2015
    gabwst17 , Aug 18, 2015 :
    can you do like a complete guide to root, if you're free that is? hahah like "rooting for dummies". like i have always wanted to root, but dont know the basics. where do i enter the commands and all?
  5. sykez
    Ice Cream Sandwich Aug 18, 2015
    sykez , Aug 18, 2015 :
    Good thing about rooting these days is you don't need to learn all that. You only need to understand what you're doing. Try WugFresh's Bacon Root Toolkit. It provides a GUI for all your needs, so you don't have to deal with the commands and stuff. Here's what you'll basically be doing:
    1. Unlock - this will wipe your device though, so make a backup somehow.
    2. Root and also flash custom recovery (TWRP is recommended).
    You'll have the stock rom with root access after this. If you want to try a custom rom instead of stock, you could just straight away flash a custom recovery after unlocking, then flash the custom rom. Most custom roms comes with root.
    gabwst17 likes this.
  6. gabwst17
    Gingerbread Aug 19, 2015
    gabwst17 , Aug 19, 2015 :
    an
    any recommended roms for my old buggy nexus 4? lol
  7. sykez
    Ice Cream Sandwich Aug 19, 2015
    sykez , Aug 19, 2015 :
    Cyanogenmod 12.1
  8. Aidenn
    Cupcake Aug 21, 2015
    Aidenn , Aug 21, 2015 :
    Hi I need some help with my phone, it keeps rebooting and I have important pictures inside. I back up with TWRP but they changed it to the stock recovery, I have important pictures inside which Google Photos did not back up. Any way to fix this ?
  9. sykez
    Ice Cream Sandwich Aug 21, 2015
    sykez , Aug 21, 2015 :
    Who changed it back? o_O Flash TWRP again. Wipe cache and dalvik cache too, then try booting. You could also use ADB pull to copy the files straight to your PC while in TWRP recovery.
  10. Aidenn
    Cupcake Aug 22, 2015
    Aidenn , Aug 22, 2015 :
    Thing is when I am in fastboot mode my PC wont recognize my phone. Downloaded all the new drivers etc
  11. sykez
    Ice Cream Sandwich Aug 22, 2015
    sykez , Aug 22, 2015 :
    Yeah, I get driver issues sometimes too. Try this toolkit. It should solve your driver issue one way or the other. Also try switching cables, could be a faulty cable.
  12. Aidenn
    Cupcake Aug 23, 2015
    Aidenn , Aug 23, 2015 :
    Tried using the toolkit , just says waiting for device. Might try using another cable. Thanks for your help
  13. sykez
    Ice Cream Sandwich Aug 23, 2015
    sykez , Aug 23, 2015 :
    Change the cable. Keep trying with different driver methods. Does your PC pick up the device at all?
