5
[MODDING] Xposed Framework
  1. Haters_Gonna_H8
    Ice Cream Sandwich Nov 1, 2014
    Haters_Gonna_H8 , Nov 1, 2014 :
    Why do it?
    Qoute from the framework’s developers:
    In summary, Xposed Frameworks allows you to tweak and gain more control over your device. With the framework + its modules, not only you can port and use features and functions from other Roms into your device, you can also apply more tweaks into your device in order to gain more privacy, increase battery life, more cosmetics mods, etc.
    Requirement to use:
    1. Your device must be rooted.
    2. Your device must be run based on Dalvik, as the framework is not yet compatible with Art runtime.
    How to install?
    1. Download and install Xposed Framework from here: http://repo.xposed.info/module/de.robv.android.xposed.installer
    2. Open Xposed Framework
    3. Click on “Framework”
    4. Click on “Install/Update”
    5. A screen will appear asking you to restart your device. Select yes to restart.
    There's an OTA, what should I do before applying the OTA ?
    1. Backup all of your data first either by Titanium Backup or Nandroid backup.
    2. Uninstall Xposed Framework. Once you had successfully applied the OTA, you may re-enable Xposed Framework with all installed modules and modules’ settings intact.
    3. Open Xposed Framework
    4. Click on “Framework”
    5. Click on “Uninstall” under Framework.
    6. Restart your device.
    7. Do the necessary steps to apply the OTA.
    8. Once OTA is applied, you may re-install/re-enable Xposed Framework as per the guide above.
    I screwed something up after playing around with the framework. Now my phone is on bootloop. How do I fix it?
    I’ve installed it. Now what?
    The framework by itself does not do anything on its own. You will need to install XF modules to benefit from the framework.
    Recommended Modules:
    1. [Battery Performance] Privacy Settings comboed with Android Tuner. Follow the guide from here: http://forum.xda-developers.com/oneplus-one/general/guide-google-play-services-battery-t2832525
    2. [Battery Performance] Amplify. Follow the guide from here: http://forum.xda-developers.com/xposed/modules/mod-nlpunbounce-reduce-nlp-wakelocks-t2853874
    3. [Battery Performance] Greenify. Follow the guide from here: http://forum.xda-developers.com/showthread.php?t=2155737
    4. [System Tweak] BootManager. Follow the guide from here: http://forum.xda-developers.com/xposed/modules/app-bootmanager-t2432359
    5. [System Tweak] Youtube AdAway. Follow the guide from here: http://forum.xda-developers.com/xposed/modules/app-t2547316
    6. [System Tweak] XPrivacy. Follow the guide from here: http://forum.xda-developers.com/xposed/modules/xprivacy-ultimate-android-privacy-app-t2320783
    7. [Cosmetic] NetworkSpeedIndicator. Follow the guide from here: http://forum.xda-developers.com/xposed/modules/xposed-networkspeedindicator-v0-9-t2636971
    8. [Cosmetic] Tinted Status Bar. Follow the guide from here: http://forum.xda-developers.com/xposed/modules/mod-tinted-status-bar-t2457265
    9. [Cosmetic] Blurred System UI. Follow the guide from here: http://forum.xda-developers.com/xposed/modules/xposed-blurred-ui-v1-0-16-07-2014-t2818273
  2. lameking91
    lameking91 , Nov 1, 2014 :
    In fact sometimes there are annoying bugs in stock rom can be fixed by xposed
  3. Jevoly
    Marshmallow Nov 2, 2014
    Jevoly , Nov 2, 2014 :
    Great work. :)
    I've link ur thread to @WeiKang's modding thread, do u need to reserve more posts for this thread? Better do so, I will help u to remove the interrupting posts such as this one which I'm typing.. :p
  4. Haters_Gonna_H8
    Ice Cream Sandwich Nov 2, 2014
    Haters_Gonna_H8 , Nov 2, 2014 :
    no need other reservation. if anyone wanna share other xposed modules are welcomed to do so.
    finaldentiny likes this.
  5. lameking91
    lameking91 , Nov 2, 2014 :
    BootManager and ActivityForceNewTask are two great stuffs.
  6. lameking91
  7. weikang2753
    KitKat Nov 3, 2014
    weikang2753 , Nov 3, 2014 :
    who is him ? :eek::eek::eek::eek::eek:
    Jevoly, kampuamee and finaldentiny like this.
  8. Haters_Gonna_H8
    Ice Cream Sandwich Nov 3, 2014
    Jevoly, weikang2753 and kampuamee like this.
  9. Jevoly
    Marshmallow Nov 3, 2014
  10. lameking91
  11. abbaszk
    Cupcake Jan 3, 2015
  12. abbaszk
    Cupcake Jan 4, 2015
    abbaszk , Jan 4, 2015 :
    ITS DONE... MULTIWINDOW
    ITS AWESOME TO WORK MUTLIWINDOW WHEN REQUIRED
  13. finaldentiny
    Community Veteran Jan 5, 2015
    finaldentiny , Jan 5, 2015 :
    Congrats!:D
    Do you mind not using the "caps" button? Thanks!
    kampuamee and Jevoly like this.
  14. Jevoly
    Marshmallow Jan 5, 2015
    Jevoly , Jan 5, 2015 :
    He wanted to show his happiness.. lol
  15. finaldentiny
    kampuamee likes this.
  16. Jevoly
    Y so happy? Eat what medicine? :p
  17. finaldentiny
  18. Jevoly
    Looks like u everyday also forgot eat. hahaha
  19. finaldentiny
    How you know geh?:eek: hahaha
  20. Jevoly
    Because I took ur medicine. :p
