Most stable Nougat Based ROM for OnePlus X
  1. dantelecan
    Gingerbread Aug 18, 2017
    dantelecan , Aug 18, 2017 :
    Thanks for the reply! I'm really glad that this ROM has the oxygen camera with manual support. Does it work well or it crashes from time to time? Also does this ROM has an FM Radio app? And one more question I saw a user complaining about WIFI/LTE problems, do you experience these problems? https://forum.xda-developers.com/showpost.php?p=73446061&postcount=289
    Thanks!
  2. rahulshaha
    Donut Aug 18, 2017
    rahulshaha , Aug 18, 2017 :
    Right now camera crashes ONLY when using beauty mod on front camera ( but hey man..... who cares for beauty mod).
    Yes the radio works fine.
    WiFi /lte all works fine for me. Just do the clean install and everything will be great.
    SOMETIMES while enabling the data there MAY be the possibility that it will not start..... For this i just head over to the access point and i tap on 3 dots (top right corner) and then tapping on SAVE option enables data. It's just a little issue that don't bothers me at all ( i experienced it only twice).
    dantelecan likes this.
  3. dantelecan
    Sounds like a really nice ROM. It might be the ROM I'm looking for. Thanks for sharing this! Did you experience any other minor bugs?
  4. Shshank Vishwa
    Honeycomb Aug 18, 2017
    Shshank Vishwa , Aug 18, 2017 :
    Lineage os... Thats what I installed on mum's phone... I update it once a month... Fast, stable....
  5. Miguel Daban
    Eclair Aug 18, 2017
    Miguel Daban , Aug 18, 2017 :
    So you said that the battery Life un resurrection remix is bad
    I dont know if to install It. If the battery is bad i won't.
    Please answer me back thank you very much
  6. rahulshaha
    Donut Aug 19, 2017
    rahulshaha , Aug 19, 2017 :
    Not yet
  7. rahulshaha
    Donut Aug 19, 2017
    Yup.... Also there is no news about the upcoming updates in RR. The last build was from 31st of may.
  8. Miguel Daban
    Eclair Aug 19, 2017
    Miguel Daban , Aug 19, 2017 :
    ok thank you but the ROM that you are using hasnt got a lot of customitation
  9. dantelecan
    Gingerbread Aug 19, 2017
  10. rahulshaha
    Donut Aug 20, 2017
    bplesa and dantelecan like this.
  11. dantelecan
    Gingerbread Aug 20, 2017
    dantelecan , Aug 20, 2017 :
    Cool, thanks a lot for taking time to answear all my questions! :D I think I found the best custom ROM for my needs :)
    rahulshaha likes this.
  12. 9891498036
    Cupcake Aug 22, 2017
  13. Generalzod
    Cupcake Aug 23, 2017
    Generalzod , Aug 23, 2017 :
    Moved to Resurrection Remix from lineage os.
    Pros :- Stability, more customization
    Cons :- Less frequent updates
  14. sushil3629
    Gingerbread Aug 24, 2017
    sushil3629 , Aug 24, 2017 :
    Have tried Lineage, AOSP Extended, Cosmic Os, Resurrection Remix and then AOSP JDC. In my view AOSP JDC is better than others if you need stability and fully working camera with manual mode, panorama, slow Mo etc. If you want clean pixel like experience go with AOSP JDC. If you are into customisation and can compromise on camera then go with any other you like.
  15. Miguel Daban
    Eclair Aug 24, 2017
    Miguel Daban , Aug 24, 2017 :
    in the AOSP CAF you can't change for example the battery icon? Am I right?
  16. sushil3629
    Rounded battery icon in AOSP JDC.. It's present in system ui tuner
  17. Miguel Daban
    Eclair Aug 24, 2017
  18. sushil3629
    #38
  19. mrawat108
    Donut Aug 30, 2017
    mrawat108 , Aug 30, 2017 :
    i want to upgrade my ONEPLUS X, is it worth to move from oxygen to this ROM. Does this ROM have gesture like oxygen OS.
    #39
  20. Kéno40
    Jelly Bean Aug 30, 2017
    Kéno40 , Aug 30, 2017 :
    Of course.
    #40
