7
Mpero Flex Flip Wristlet Wallet case for Oneplus One.
  1. hotsauce
    Lollipop Sep 27, 2014
    hotsauce , Sep 27, 2014 :
    Just got this cool looking Wristlet case for my OPO. They have different faux leather finish as well, this one is black lace material.
    SoniaB, anshul2, projekt1 and 4 others like this.
  2. Linanc7
  3. Mark1986
    Ice Cream Sandwich Sep 27, 2014
    Mark1986 , Sep 27, 2014 :
    It's very nice. Might clash with my shoes, but I think I could make it work.
    badsqwerl, mihirrao, gdsob138 and 3 others like this.
  4. sstalinov
    Cupcake Sep 27, 2014
  5. veratoloz2005
  6. brodskyf
    brodskyf , Sep 27, 2014 :
    Looks nice but I dont have anything to go with it.
    Hope it works out well for you.
  7. Reggie1026
  8. rainqueen
    rainqueen , Sep 27, 2014 :
    Lace gone wild.
    veratoloz2005 likes this.
  9. Aaroneloy21
    Jelly Bean Sep 27, 2014
    Aaroneloy21 , Sep 27, 2014 :
    I th
    I think you can pull it off
  10. Reggie1026
    Reggie1026 , Sep 27, 2014 :
    Im not talking about your avatar, i'm talking about the Never Settle shirt..
  11. Mark1986
    I'll be the prettiest one at the ball.
    Nilesh Sajnani and Aaroneloy21 like this.
  12. Aaroneloy21
  13. jymh890
    Froyo Oct 22, 2014
  14. patchydel
    Cupcake Oct 22, 2014
  15. nagem145
    Cupcake Oct 23, 2014
    nagem145 , Oct 23, 2014 :
    I've seriously been looking all over for something like this, where did you find it?!
  16. jd13
    Cupcake Nov 19, 2014
  17. jd13
    jd13 , Nov 19, 2014 :
    I'm planning to buy the mint green version of this one, how does it fit on the oneplus? Are there any flaws with this case?
    the reviews are all over the place!
    http://www.amazon.com/MPERO-FLEX-FLIP-Wallet-OnePlus/dp/B00N1CSK4M/ref=cm_cr_pr_product_top
  18. Kwok
    Cupcake Dec 18, 2014
    Kwok , Dec 18, 2014 :
    when you put your cards on it, have you found that it has started to mark/scratch the screen protector?
  19. jd13
    Cupcake Jun 4, 2015
    jd13 , Jun 4, 2015 :
    I've had the case for five months, the cards don't scratch the screen at all.
    I have the mint green one. It gets pretty dirty easily, especially the inside where you put your phone in, but I don't find it a problem at all. The white rubber casing in the inside doesn't fit as well, it's a bit snug, and the buttons aren't cut perfectly, it's not exactly a big deal, you just have to press harder on the sound buttons and what not. I would rate this case a 3/5. But I will keep using it because it's practical to have a wallet case when you're commuting all the time and need a place to put your public transit card
