Multiple issues with OnePlus Buds Pro
  1. Harsh PB
    Cupcake Sep 9, 2021
    Harsh PB , Sep 9, 2021 :
    There are 4 issues I'm facing (using OnePlus 7 Pro)
    1. The right ear bud creats a sign tone for a few seconds before completely muting. For example when I'm playing music or watching a video and I stop media playback for a few seconds there is a sign tone playing in the right earbud and then it stops, the same thing happens on calls. (Have tried on other devices and the issues is consistent)
    2. There is no option for completely disabling transperancy mode, sometimes the left ear bud activities transparency mode where as the right ear bud will play with noise cancellation OFF setting.
    3. Pop-Up notification for connection and battery status - There is no option to disable this and it's a nuisance sometimes because apps like YouTube, Netflix, Amazon Prime will go into pip mode because of the pop-up or stop playing the video completely.
    4. The case rattles - The lid rattle while it's closed but doesn't rattle when fully opened. Is this issue faced by everyone or did I recieve a defective product?
  2. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Sep 10, 2021
    Liehjan , Sep 10, 2021 :
    1. Try to reset buds and check that buds app and firmware is up to date.
    2. Same as nr1.
    3. There is no way to disable this, the pop-up animation is by design.
    4. How loose is it? A little play is normal.
  3. Harsh PB
    Cupcake Sep 10, 2021
    Harsh PB , Sep 10, 2021 :
    The problem 1 and 2 are still there, I did reset.
    The case is a little loose not much!
  4. F1633449581350
    Cupcake Oct 12, 2021
    F1633449581350 , Oct 12, 2021 :
    Are these defective i just received oneplus buds pros but after few days right buds always showing 10% less charge it can be fixed or i received a defective unit ?
  5. F1633449581350
  6. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Oct 13, 2021
    Liehjan , Oct 13, 2021 :
    Battery life is just an estimate. It you want to be sure use both buds untill battery runs out.
    Are you using one bud all the time for controls? If so, switch to the other side once in a while.
  7. RishulOberoi
    Donut Dec 8, 2021
