Working
multy touch problem
  1. I1560334897023 Cupcake Jul 13, 2019
    I1560334897023, Jul 13, 2019 :
    i am testing my mobile with an app name multy touch test and i saw that i put one by one finger on screen its working but i put 2-3 or more fingers together its was not working. please fix this problem.
  2. Horsault Marshmallow Moderator Jul 13, 2019
    Horsault, Jul 13, 2019 :
    Can you swipe, zoom into your pics, etc.?
    Yes?
    Then multitouch is working, whatever this silly 3rd party app is telling you.
    Look at reality, not at test from the 1st app you're using.
    And if multitouch is working, then it's a proof your app is crap.
  3. Gav_W86 Starting Point Expert Jul 14, 2019
    Gav_W86, Jul 14, 2019 :
    it is likely a poor app, as said, you can easily test by pinch zooming on a photo in gallery.
  4. I1560334897023 Cupcake Jul 16, 2019
    I1560334897023, Jul 16, 2019 :
    am playing pubg game and i use 3 finger bt whenever i press 2 finger together its was not working many times .
  5. Gav_W86 Starting Point Expert Jul 16, 2019
    Gav_W86, Jul 16, 2019 :
    if it is not working 'many times' in one app only it is more likely to be the app. Is it fine in other apps?
  6. I1560334897023 Cupcake Jul 17, 2019
    I1560334897023, Jul 17, 2019 :
    i have also a one plus 6t bt its was working properly
  7. Gav_W86 Starting Point Expert Jul 17, 2019
    Gav_W86, Jul 17, 2019 :
    doesn't mean it is not the app.
    does the touch work fine in other apps?
