21
My 7 Pro EQ Setting! A must try!
  1. Shan32
    Cupcake Jul 17, 2020
    drummer79 likes this.
  2. rak4055
    Donut Aug 14, 2020
    rak4055 , Aug 14, 2020 :
    Awesome sound brother.. thumps up.
  3. 1bhavin12001
    Gingerbread Aug 14, 2020
  4. Hasmir
    Cupcake Aug 20, 2020
  5. devb95
    Honeycomb Aug 21, 2020
  6. M1577199986704
    Cupcake Aug 21, 2020
  7. M1577199986704
  8. I1594372313796 , via OnePlus 8 Pro , Nov 19, 2020 :
    Guys I'm using Sony WH-1000XM3's and they support LDAC. I want pure bass. Can someone help with EQ settings? I'm on my OnePlus 8 Pro. With bass I want vocals to be clear af too :)
  9. drummer79
    Gingerbread Nov 19, 2020
    drummer79 , via OnePlus 8 Pro , Nov 19, 2020 :
    Have you tried setting the pre set EQ's on the Sony Headphones AP? In my opinion the "Excite" setting should give you just what your looking for. Then you can just set Dolby Atmos to Dynamic and leave the EQ alone on the 8 Pro otherwise.
  10. I1594372313796 , via OnePlus 8 Pro , Nov 19, 2020 :
    I have already set pre set EQ to +5 bass boost in sony headphones app. But the main problem is that the codec switches to SBC from LDAC. Btw I use apple music on Android. Is there any difference b/w LDAC and SBC especially if I'm using apple music.
  11. drummer79
    Yes! There is a huge difference between SBC & LDAC! SBC is basically the lowest quality Bluetooth Codec offered and LDAC is the best. LDAC is Lossless audio. You will hear the music at its best, the way it was recorded in studio.
  12. I1594372313796 , via OnePlus 8 Pro , Nov 20, 2020 :
    So does that mean I should leave it to LDAC and use OnePlus' built-in EQ? Can you suggest me best setting for the same (excellent bass and good vocals)
  13. drummer79
    Gingerbread Nov 20, 2020
    drummer79 , via OnePlus 8 Pro , Nov 20, 2020 :
    I have the Sony WF-1000XM4 and as you know they are incredible. I also use them with the 8 Pro. Here's what I do. I set the Sony "Headphones" app to the (Excite) EQ setting. Then I just keep my 8 Pro set to Dynamic on the Dolby Atmos setting. As far as the EQ setting on the OnePlus phone, I don't use them. I keep that EQ off because I don't like to have more than one EQ setting at a time. Mine sounds terrific just like that and I'm sure yours will too. If you feel you still wanna try the EQ on the phone then I have one on this post. I commented that it keeps the bass and brings up the kids and highs. That one should give you bass and vocals like you are wanting. But, in my opinion, those Sony Headphones sound so good without it I think you would be better off doing it the way I like. Hope this info helps!
  14. drummer79
    And YES, use the LDAC codec as much as you can. It is the best quality audio you will get!
  15. I1594372313796 , via OnePlus 8 Pro , Nov 21, 2020 :
    Oh so now I got it. You have XM4 which can play LDAC+ in-app EQ, whereas XM3 can only play in-app EQ but with just SBC (no LDAC).... That's quite sad considering they are almost same pair of headphones with minor tweaks... Can you now suggest me what should I do as I can only use SBC with in-app EQ?
    Will this do the job which you posted in this thread?
  16. drummer79
    Gingerbread Nov 21, 2020
    drummer79 , via OnePlus 8 Pro , Nov 21, 2020 :
    Yep, use the EQ in the comment #7 on this post. That should help.
  17. I1603556967440 , via OnePlus 7 Pro T-Mobile , Nov 23, 2020 :
    Agreed. The original suggested settings sound the best on my OnePlus 7 Pro. Great work! Thanks for the suggested settings.
  18. adepumukesh
    Cupcake Nov 30, 2020
    adepumukesh , Nov 30, 2020 :
    Thanks for the suggestion, It helped me alot, I even cancelled my decision to buy a new bass earphones as it helped me in getting what I need, I mean bass, It renewed my opbwz with bass
    #38
  19. F1569085450722
    Cupcake Mar 27, 2021
    #39
  20. drummer79
    Gingerbread May 16, 2021
    #40
    F1569085450722 likes this.
