My 8T is on its way
  1. carloxxpo
    Cupcake Jun 18, 2021
    carloxxpo , Jun 18, 2021 :
    Hello Folks,
    I just ordered my first Oneplus phone (coming from an iPhone 6s Plus). What do you usually recommend doing? (Casual user to photos and 1-2 hours gaming)
    • Update to its latest firmware?
    • Battery drain to test its capability?
    • Maximize the refresh rate?
    • Enable developer option to tweak more options?
    I am just as excited as a fifth-grader who is about to get his toy, Apologies ^^
  2. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Jun 18, 2021
    Liehjan , Jun 18, 2021 :
    • Update to its latest firmware? -Yes
    • Battery drain to test its capability? -Not necessary
    • Maximize the refresh rate? -Yes, display looks bad at 60hz
    • Enable developer option to tweak more options? -If you want, not necessary
    NaXal, Tobikage, carloxxpo and 2 others like this.
  3. McJader
    Marshmallow Jun 18, 2021
    McJader , Jun 18, 2021 :
    Yep.
    For the first charge you can try, but generally keeping the battery percentage between 80 and 20 is considered a good idea.
    Sure.
    Only if you know what you're doing.
  4. G_subhash_challa_ySvx
    Gingerbread Jun 19, 2021
  5. H1623994670099
    Cupcake Jun 21, 2021
  6. Lucy0187
    Gingerbread Jun 21, 2021
    Lucy0187 , via OnePlus 8T , Jun 21, 2021 :
    I have the 8T since it came out runs good. Mirror bugs but that's with every phone has something. Probably upgrade to the 10 when it comes out.
    carloxxpo and McJader like this.
