my camera is not working
  1. L1520167709702 Cupcake Jul 17, 2019
    L1520167709702, Jul 17, 2019 :
    I have changed both cameras but this sign come again and again.. What would i do next?
    I have no spare money to through on camera's.
    And yes there is no support center here
  2. Ricky1394 Ice Cream Sandwich Jul 17, 2019
    Ricky1394, Jul 17, 2019 :
    Try to update camera software from apk mirror website..
    Find compatible version of camera from there..
    Example...for Android 9 pie API 29 is there.
    Download it and install that apk and open your camera.
    Hope it will fix your problem.
  3. ghostofcain Marshmallow Jul 17, 2019
    ghostofcain, Jul 17, 2019 :
    Changed both cameras how, hardware replacement? Have they ever worked after replacement? I assume you've tried factory resetting and clean flashing stock ROM?
  4. palc Ice Cream Sandwich Jul 17, 2019
    palc, Jul 17, 2019 :
    I believe he meant he's tried to change between both front and back cameras and not that he did a hardware replacement..
    Anyway, solution to this can be:
    Clearing cache, uninstalling all updates to camera app from settings, and restarting your phone once. I had the issue once and doing the above sorted it.
  5. L1520167709702 Cupcake Jul 19, 2019
    L1520167709702, Jul 19, 2019 :
    palc
    Clearing cache, uninstalling all updates to camera app from settings, and restarting your phone once. I had the issue once and doing the above sorted it.​
    Hardware replacement.. And i do everything
  6. palc Ice Cream Sandwich Jul 19, 2019
    palc, Jul 19, 2019 :
    My bad, sorry.
  7. ghostofcain Marshmallow Jul 22, 2019
    ghostofcain, Jul 22, 2019 :
    Everything? So what did the repair shop say when you returned it as non functional?
