My charger is not detecting fast charging. via OnePlus 6
  1. Supraj_Kumar_K
    Donut Aug 6, 2020
    Supraj_Kumar_K , via OnePlus 6 , Aug 6, 2020 :
    I am using the same One Plus charger from the time of purchase. But now a days my charger is not detecting fast charge, sometimes even though it's detected again and again its disconnected and normal charge happening. This happens only one side of charger, but not other side. As its a type-c we can connect any side. Anyone facing or faced the same issue?
    Pls help me out on this.
    O1578192316190 likes this.
  2. drl431
    Community Hero 2020 Aug 6, 2020
    drl431 , Aug 6, 2020 :
    Try cleaning out the usb-c connector on the phone. Use a toothpick or similar non-metallic probe. Look for pocket lint.
    rHITkM, sniadr and Caomhin like this.
  3. Supraj_Kumar_K
    Donut Aug 6, 2020
    I tried but no luck. Tha thing its behaving like this at one side of the charger. I don't know why its behaving like this. And am seeing so many issues with the charger and software of one plus in recent times.
  4. drl431
    Check and clean the usb-c connector on the phone carefully, as the next step is to replace the cable or visit a service center. As to software issues, I think most are related to a dirty flash of Android 10 and that some apps are not fully compatible with it.
    rHITkM and Caomhin like this.
  5. Hamza Fayyaz
    Donut Aug 6, 2020
  6. drl431
    The 10.3.5 update works fine in my OP6. Clean the charging port as detailed 3 posts above yours.
  7. Hamza Fayyaz
    Donut Aug 6, 2020
    Hamza Fayyaz , Aug 6, 2020 :
    Its cleaned was working 15 mins before the update :( I shouldn't have updated from android 9
  8. Artemus.
    Artemus. , Aug 6, 2020 :
    Check the cable for damage.
    rHITkM, Caomhin and drl431 like this.
  9. Hamza Fayyaz
    Donut Aug 6, 2020
    Cable is fine. I have tried 2 different cables.. And When I try to connect to my laptop I am getting is error unless I restart several times..
  10. Artemus.
    Each cable has this specific issue?
    drl431, rHITkM and Caomhin like this.
  11. Hamza Fayyaz
    Donut Aug 6, 2020
    Yes.. My pc detects it sometimes but after few mins it gets disconnected and this msg comes up,, and for charging blue lights comes up then it turn red it keep happening like for a min or 2 and then it will start charging it on normal speed with red light on,,, All this happened right after I update it to 10.3.5 update
  12. Artemus.
    When is the last time you formatted your phone?
  13. O1578192316190
    Donut Aug 6, 2020
    O1578192316190 , Aug 6, 2020 :
    I started facing the same issue guys , when i put my charger on it starts with fast charging then disconnect again connect again disconnect and continuing with normal charge.
    what can i do please help me
  14. Hamza Fayyaz
    Donut Aug 6, 2020
    Never Since I bought it 2 years ago.
  15. LittleFlower
    Eclair Aug 6, 2020
    LittleFlower , Aug 6, 2020 :
    Don't you remember that the charger fell somewhere? It can be damaged or dirty inside. I am facing a problem in slow charging but I am going to buy a new charger tomorrow, let's see if it gets better
  16. Hamza Fayyaz
    Donut Aug 6, 2020
    Yes EXACTLY SAME ISSUE WITH ME.. Attaching video for reference
  17. Hamza Fayyaz
    Donut Aug 6, 2020
    No man it didn't fell anywhere it was charging fine like 5 mins before the update..
  18. O1578192316190
    Donut Aug 6, 2020
    i doesn't recieved any update from one plus. it works properly in morning. Problem starts from evening when am clearing cache files from power off,+volume down button then put my phone on charge and problem starts
  19. LittleFlower
    Eclair Aug 6, 2020
    Yeah I was wondering that it could be something about the update...
  20. O1578192316190
    Donut Aug 6, 2020
    Supraj_Kumar likes this.
