My display have burnd and my phone is heated too much via OnePlus 7 Pro
  1. Vijaymalik00
    Cupcake Jun 14, 2021
    Vijaymalik00 , via OnePlus 7 Pro , Jun 14, 2021 :
    Today at 1:42 PM
    I am a Oneplus 7pro user and I have had a heating issue since February and they are not able to give me any proper solution and in my phone screen some unwanted icons display on my phone screen. I visited the service center on 12 June 2021. they did not accept my phone to check the problem they said this is just a normal temperature issue. At that time my phone temperature was 46.4. I can attached both screenshots in this mail for heat issue and screen issue . this icon is visible on screen
  2. McJader
    Marshmallow Jun 14, 2021
    McJader , Jun 14, 2021 :
    Display burn-in isn't due to heating.
    It's due to using the same app for long periods of time at High brightness.
    And yes,they weren't wrong about the temperature, it's nothing out of the ordinary, especially when playing games.
    Liehjan, Artemus. and J4t1np4r3kh like this.
  3. J4t1np4r3kh
    OnePlus Accessory Tester Jun 14, 2021
    J4t1np4r3kh , Jun 14, 2021 :
    Oh man, that's quite a bit of burn-in.
    You know what I never understand, surely that level of burn in doesn't happen in one day of playing. So don't you start realising to reduce play hours or reduce brightness at least?
    Liehjan, Artemus. and McJader like this.
  4. Vijaymalik00
    Cupcake Jun 17, 2021
    Vijaymalik00 , via OnePlus 7 Pro , Jun 17, 2021 :
    Is finger print is also count in gameing
  5. Vijaymalik00
    Ooh that mean I have to ignore finger print scanner because there is print of that too
  6. J4t1np4r3kh
    OnePlus Accessory Tester Jun 17, 2021
    J4t1np4r3kh , Jun 17, 2021 :
    Yeah not sure about that, potentially the burn in was so bad in the region that it captured the images immediately after from that area too 🤷‍♂️
    I found the following online:
    "Screen burn occurs when an old image lingers on the screen even after the phone itself has moved on to display the next image. There is a greater risk of screen burn in high use areas of the phone, including the area around an in-display fingerprint sensor."
    I guess it's the regular use of that at such a high brightness that causes the burn in
    McJader likes this.
  7. bcharles99
    Honeycomb Jun 17, 2021
    bcharles99 , via OnePlus 7 Pro , Jun 17, 2021 :
    After OOS11 update I also faced screen burn issue...I am not a Gamer, not using screen at full brightness.i always using dark mode since I purchased my device..I don't know what is the exact reason for the issue...my status bar battery icon , signal icon volte icon time are static every time particularly in white background...
  8. Md_Robin
    Donut Jun 18, 2021
  9. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Jun 19, 2021
    Liehjan , Jun 19, 2021 :
    You can hide the icon on A11, I would recommend that.
    Artemus. likes this.
  10. Liehjan
    Looks like a free to play game got really expensive whit that amount of burn-in... Check repair pricing on oneplus.in website.
  11. Vijaymalik00
    Cupcake Jun 19, 2021
    Vijaymalik00 , via OnePlus 7 Pro , Jun 19, 2021 :
    My Phone is in warranty then why should i check price.
  12. McJader
    Marshmallow Jun 19, 2021
    McJader , Jun 19, 2021 :
    How do you think a reset will solve a Hardware issue?
  13. Liehjan
    It's not covered by warranty as the burn-in is caused by your gaming habits and not by failing hardware, so be prepared to pay for parts and labor.
  14. Vijaymalik00
    This is hardware issue and os 11 not my fault
  15. McJader
    Good luck getting it done for free then o_O
  16. Liehjan
    The PUBG incons stuck on screen has nothing to do with A11 update... And as screen burn-in isn't covered by warranty you are extremely lucky if they fix it for free. Try to be really friendly when talking to service center or support will increase your chances.
