My lock box password how to forget via OnePlus 6
  1. R.ajith Kumar
    Cupcake Jan 24, 2020
  2. drl431
    Marshmallow Jan 24, 2020
    drl431 , Jan 24, 2020 :
    Back-up your data, and move it to a pc or the cloud, then do a factory reset.
    Kytharsis likes this.
  3. R.ajith Kumar
  4. drl431
    Don't know, those might be lost. But try using the OnePlus Switch app for back-up, and do not back-up apps and system settings. Then see what happens after a factory reset. You can also try contacting OnePlus customer service.
  5. DrJMun
    KitKat Jan 24, 2020
    DrJMun , Jan 24, 2020 :
    Data in LockBox is encrypted. You should first unlock the LockBox and move the data out if you wish to be able to back it up in a fashion you can use it later.
