My nord is not connect earbuds z via OnePlus Nord
  1. kadianashu
    Cupcake Oct 31, 2020
    M1602955734416 likes this.
  2. F1599205882544
    Ice Cream Sandwich Oct 31, 2020
    F1599205882544 , via OnePlus Nord , Oct 31, 2020 :
    As these OnePlus Earbuds Z are quickly detected and connected to the OnePlus Nord you can verify :
    - if your bluetooth is activated,
    - if you have upgraded your device to latest firmware OxygenOS 10.5.9
    - occasionally reset your bluetooth parameters in Settings / System / Reset Options / WiFi, Mobile data, Bluetooth and reboot.
    - retry
  3. keithnyc
    Marshmallow Moderator Oct 31, 2020
    keithnyc , Oct 31, 2020 :
    any luck connecting, mate?
    kadianashu likes this.
  4. kadianashu
    kadianashu , via OnePlus Nord , Oct 31, 2020 :
    I am already try this tip but not connected and my 1+ 8 connected this device
  5. kadianashu
    My oxygen os is 10.5.8 AC01DA version
  6. F1599205882544
    Hope the device doesn't try to connect your OP 8 and simultaneously your Nord. Remove it from OP 8 bluetooth and retry ...
    Or also reset the earphones to factory settings according to instructions.
    Don't forget to upgrade to OS 10.5.9 with Oxygen Updater v4.5.1 from PlayStore !
  7. kadianashu
    Iam try but not connected
  8. kadianashu
