my one plus 5t gets restart automatically sometime.
  1. E1518166354358
    Cupcake May 18, 2018
  2. Anand_Sagar18
    Jelly Bean May 18, 2018
    Anand_Sagar18 , May 18, 2018 :
    that's normal. before that make sure that is not frequent.
    if it is happening in 3-5 days ... then let it be . or you can try yourself restarting your device once in 3 days.
  3. haimgreenberg
    Honeycomb May 18, 2018
    haimgreenberg , May 18, 2018 :
    are you serious ???
  4. Anand_Sagar18
    yes. it does reboot. for most of the device. if the stand by time is greater than 100 hours. theoretically it should not happen , but I have observed with 3 of devices 1 OnePlus 5 and 2 OnePlus 5t. and the above is 4th case I am getting.
  5. [email protected]
    Donut May 18, 2018
  6. bharadwaj_k1
    Gingerbread May 18, 2018
    bharadwaj_k1 , May 18, 2018 :
    As I remember thread existing for the same..You may find solutions over there. Check it out.
  7. E1518166354358
  8. kartyperumal
    Eclair May 18, 2018
    kartyperumal , May 18, 2018 :
    it's not hardware issue..when u actually getting restart..while keeping in pocket or screen directly facing to my object?
