My one plus 7t wifi speed is too low via OnePlus 7T
  1. M1589792946984
    Cupcake Aug 27, 2020
    M1589792946984 , via OnePlus 7T , Aug 27, 2020 :
    My one plus 7t wifi speed is too low for the last few days but my all the other devices are getting good speed. Kindly see the comparison between my one plus 7t and samsung note 9 on the same network at same location and time.
  2. K1598077079499
    M1589792946984 likes this.
  3. Caomhin
    Marshmallow Aug 28, 2020
    Caomhin , via OnePlus 6T , Aug 28, 2020 :
    Reset your Wifi Network Adapter, see if it can help.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth
    Liehjan likes this.
  4. M1589792946984
    Cupcake Aug 28, 2020
    M1589792946984 , via OnePlus 7T , Aug 28, 2020 :
    Already tried but no use
    Caomhin likes this.
  5. Caomhin
  6. BENSON IDICULA MATHAI , via OnePlus Nord , Sep 21, 2020 :
    Same issue in OnePlus Nord also,but some difference is there, while checking in google chrome Google search speed shows slow and while checking with Google search engine it shows the real speed
  7. Caomhin
    Marshmallow Sep 21, 2020
    Caomhin , via OnePlus 6T , Sep 21, 2020 :
    Try with Ookla Speed test app from the Playstore , it's usually pretty good measurement, though you may need to pick different test servers.
    Try it on different phones for comparison on the same network, if you have access to more than one, will test any connection 4G, 5G and WiFi.
    https://play.google.com/store/apps/details?id=org.zwanoo.android.speedtest
  8. BENSON IDICULA MATHAI , via OnePlus Nord , Sep 21, 2020 :
    Ookla can't be trusted like google speed test.
    Ookla always shows average speed
  9. Caomhin
    Yes, have used it for years and compared to many other speed test apps and websites and its pretty accurate. Yes it takes an average speed of a file to download. But that's normal. It gives you the overall picture. As there can always be fluctuations in speed depending on many factors.
    Bouncer71 and Q1588840742947 like this.
  10. BENSON IDICULA MATHAI , via OnePlus Nord , Sep 21, 2020 :
    Here the issue is on same network OnePlus and other phones showing different speeds and it was not like this before
    Ankeetvora likes this.
  11. #11
  12. Caomhin
    Marshmallow Oct 3, 2020
    Caomhin , via OnePlus 6T , Oct 3, 2020 :
    Nothing wrong with my 5ghz WiFi. Have 360Mbps Broadband, getting 350Mbps down and 36 Mbps up.
    And that's on a 6T
  13. #13
  14. Caomhin
    Here's a few thing to try on the phone, links have further info as well.
    Reset your WiFi adapter, see if that helps.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    Also Go to Settings->Battery->Battery Optimization->Search com.oneplus.wifiapsettings -> Change this to "Don't optimize"
    How To Fix Common Wi-Fi Problems In Android
    https://www.techjunkie.com/fix-wi-fi-problem-android/
    Also a suggestion here for 8 Series but some of the suggestions may crossover to other OnePlus series phones.
    https://forums.oneplus.com/threads/my-findings-of-the-5-ghz-wifi-connection-issue.1221263/
    Bouncer71 likes this.
