10
My One Plus wireless bullet Z white light is continuously on
  1. Addu5221
    Eclair Jun 23, 2020
    Addu5221 , Jun 23, 2020 :
    Hey, Kindly help
    My wireless bullet Z while light is not going off.
    Even if I join the magnetic ends of buds it does not go off.
    I tried charging it to force red light to switch place but red light lids on top of white light, giving whitish red light, factory reset failed.
    Purchased it two days back and was working fine till yesterday and only since the morning I have observed this.
  2. venuprasadh
    Cupcake Jul 1, 2020
  3. Addu5221
    Eclair Jul 1, 2020
    Addu5221 , Jul 1, 2020 :
    Being a One plus fan I am really disappointed at product quality. Had to end up with returning the product. I discharged it complete and white light went out but then on charging it appeared again. So it simply concludes that the wiring was shorted. Kindly return if possible
    venuprasadh likes this.
  4. Ijaz17
    Donut Jul 3, 2020
    Addu5221 likes this.
  5. ChaitanyPandiya
    Cupcake Jul 8, 2020
    ChaitanyPandiya , Jul 8, 2020 :
    I just purchased the earphones and wasnt able to connect also with my op7 but light is continuously on, so should i just return?
  6. Addu5221
    Eclair Jul 8, 2020
    Addu5221 , Jul 8, 2020 :
    Yes in no time
  7. ChaitanyPandiya
    Cupcake Jul 8, 2020
    As i did the mistake of ordering from one plus itself guess i will have to first ship it out to their service centre and then they will see
  8. ChaitanyPandiya
    Cupcake Jul 8, 2020
    And also I have not been able to connect it at all so even though white light is on I am not able to search for it
  9. Addu5221
    Eclair Jul 8, 2020
    One plus had two aspects that differentiated it.
    High quality build
    Quality service
    It has started loosing both.
    Ijaz17 likes this.
  10. ChaitanyPandiya
    Cupcake Jul 8, 2020
    yes I am highly disappointed as if I would have ordered from Amazon i would have got a free replacement
  11. F1592129357490
    Cupcake Jul 21, 2020
    F1592129357490 , Jul 21, 2020 :
    B
    Bro what is the solution of this plzz tell me
  12. yashwant24
    Jelly Bean Jul 25, 2020
  13. R1595074442001
    Cupcake Jul 27, 2020
    R1595074442001 , Jul 27, 2020 :
    Faced same issue after 3 days of usage. Disappointed. Another mistake bought it from OnePlus website and not Amazon. Anyone got solution for this till now?
  14. Y1577080377956
    Y1577080377956 , via OnePlus 7 , Jul 27, 2020 :
    I'm happy to share the I'm one plus 7 user. one plus z bullet earphones was not worthy. Received a defect piece. After plugging 10+ hrs it's coming into white blinks it's starting after resetting. Still the mail's are going with one plus support for replacement. Unworthy product in one plus is one plus z bullet earphones. Disappoints alot.
  15. jo...
    Cupcake Aug 4, 2020
    jo... , Aug 4, 2020 :
    facing the same issue, dim white light is constantly on. If anyone got the solution please let me know. thanks.
  16. yashwant24
    Jelly Bean Aug 4, 2020
    yashwant24 , via OnePlus 6 , Aug 4, 2020 :
    There is no solution for this.
    It is an indicator that the earphones are connected.
    If you feel annoying,then use some kind os tape to wrap it, this is the only possible solution.
    Covering or wrapping it.
  17. R1595074442001
    Cupcake Aug 6, 2020
    R1595074442001 , Aug 6, 2020 :
    Man, issue is not this. Issue is white light is constantly on and its stuck. Earphones are neither getting detected nor connected. Read/Understand the thread completely before you peek in!!
  18. jo...
    Cupcake Aug 6, 2020
    jo... , Aug 6, 2020 :
    wow man! thanks for the valuable input. But Sadly it is not what you are thinking. As I had been using the headphone for more than one month, I think I know what are the basic functions of the LED indicator on the headphone. All of us facing a issue which has made the headphone useless. still thanks for your 'valuable' input.
  19. yashwant24
    Jelly Bean Aug 6, 2020
    yashwant24 , via OnePlus 6 , Aug 6, 2020 :
    Seriously, I use a Bullet wireless 2 I too feel it annoying.
  20. soumjena
    Cupcake Aug 6, 2020
    soumjena , via OnePlus 8 Pro , Aug 6, 2020 :
    I faced the same just an hour ago while receiving a call I just detached the magnetic ends and it didn't connect to my phone and later I see the dim white light and no connectivity to device. Even while charging the same light is seen and no red light.
    Any resolution to this ?
    vishnu5443 likes this.
