10
My One Plus wireless bullet Z white light is continuously on
  1. jo...
    Cupcake Aug 6, 2020
    jo... , Aug 6, 2020 :
    firstly annoyance with a feature of a working device and annoyance with a defective device are of completely different level. Secondly when you are not using the device that is in the discussion, I think it is better not to comment. But who am I, it is a free world and anyone can give his or her "VALUABLE" inputs.
  2. jo...
    Cupcake Aug 6, 2020
    I got the same kind of problem 2days back. still has not find solution. But got an idea fro. another thread and trying that. I have kept the earphones unpaired. Hopefully it will drain out the battery and give me a chance to restart it. But the problem is, I am not quite sure how long it will take to completely discharge( other thread mentioned 4-5 days).
  3. soumjena
    Cupcake Aug 6, 2020
    soumjena , via OnePlus 8 Pro , Aug 6, 2020 :
    I'm trying the same and the one gets the issue solved first will let the other know about it mate. [e]1f60a[/e]
    jo... likes this.
  4. yashwant24
    Jelly Bean Aug 6, 2020
    yashwant24 , via OnePlus 6 , Aug 6, 2020 :
    I know about that device from the left earpiece to the right.
    Secondly, there is only a slight difference between Bullet wireless 2 and Bullet wireless z.
    As you said this is a free community, I can comment anything by following community rules and I will do
  5. jo...
    Cupcake Aug 6, 2020
    sure... it is free for all
  6. yashwant24
    I can give you another valuable input.
    Try resetting the device.
    To reset the device simultaneously press and hold volume-up and volume-down buttons for 10seconds.
    This will erase all pairing records and you must pair with every device once again.
  7. jo...
    Cupcake Aug 6, 2020
    again thanks for the "valuable" input.
    NONE of us had gone through the manual, NONE of us had this idea of factory resetting. Even the person who started this tread didn't had this idea and I think that is why he wrote "factory reset failed.".
  8. soumjena
    Cupcake Aug 6, 2020
    Hey Yashwant, I tried with that but it's not working.
  9. jo...
    Cupcake Aug 6, 2020
    sure bro [e]1f44d[/e]
  10. yashwant24
    Afraid service center is your next stop.
    If it is in replacement period try replacing it.
  11. yashwant24
    Yeah!!!
    Thanks for opening my eyes.
    Didn't notice that.
  12. DrAakanksha
    Cupcake Aug 6, 2020
    DrAakanksha , Aug 6, 2020 :
    Had the same issue yesterday. Let it discharge for a day by disconnecting the magnets till the white light becomes off. Took mine 24 hours for that. Charge again for 15-20 mins. Worked for me. It's back to normal for now.
    jo... likes this.
  13. soumjena
    Cupcake Aug 6, 2020
    Thanks buddy. I hv kept it to discharge also it had 30 percent battery the last time I noticed. Will follow as you said and will let you know all.
  14. jo...
    Cupcake Aug 6, 2020
    finger crossed with my one also
  15. soumjena
    Cupcake Aug 7, 2020
    soumjena , via OnePlus 8 Pro , Aug 7, 2020 :
    I followed the same as you instructed and it worked. Thanks Doc. [e]1f60a[/e] I saved some bucks.
    jo... likes this.
  16. braj_meena
    Cupcake Aug 8, 2020
    braj_meena , Aug 8, 2020 :
    Hi, my earphones are discharging from 7 days and don't know how much more time it'll take tk discharge completely.
  17. Plenue
    Donut Aug 8, 2020
    Plenue , via OnePlus 5T , Aug 8, 2020 :
    Same issue happened to my bullet z today received yesterday. Will try draining. Please do suggest how to solve if draining battery doesnt works.
  18. Starcommander
    Lollipop Aug 8, 2020
    #38
  19. yashwant24
    Jelly Bean Aug 8, 2020
    yashwant24 , via OnePlus 6 , Aug 8, 2020 :
    They did it and it didn't work out,
    Surprisingly they found another solution.
    To drain out the battery and start again.
    #39
  20. DrAakanksha
    Cupcake Aug 8, 2020
    DrAakanksha , Aug 8, 2020 :
    Wait for a couple more days maybe.. the battery must have been fully charged when this had happened. In the meanwhile try contacting OnePlus. Not that they're responding though. I still haven't received a reply to my mail from 4 days ago.
    #40
