7
My Oneplus 3 Battery Problem After updating to Android Nougat (oxygen os 4.0)..
  1. Vivek transzakle Gupta Eclair Jan 2, 2017
    Vivek transzakle Gupta, Jan 2, 2017 :
    My Oneplus 3 Battery Problem After updating to Android Nougat (oxygen os 4.0) from 3.2.8
    Full description: I was having Oxygen OS 3.2.8 before I updated to Oxygen OS 4.0 (Android Nougat 7) through a VPN named as Snap by connecting to Canada Server on the 1st day of this year (2017) and after installing the update i was unable to see my contacts and was unable to use phone dialer app and my battery drained like 20% in 20 mins without opening the phone and without using the 4G or any network connection and also the phone was in airplane mode and still this battery draining happened ...after factory reseting my oneplus 3 today, the contact and phone dialer app is ok but the battery draining problem is till there ...
    I want someone to help me in stopping the battery draining problem ....i already factory reset my phone after the nougat update so I dont want to factory reset again ....i am attaching some screenshots of my oneplus 3 battery draining problem..... Thanks in advance please help
      File size:
      104.7 KB
      2,749
      File size:
      70.3 KB
      3,075
      File size:
      137.6 KB
      3,018
      File size:
      90.9 KB
      2,379
  2. Android450 Marshmallow Jan 2, 2017
  3. JasonMR Lollipop Jan 2, 2017
    JasonMR, Jan 2, 2017 :
    Try using more than 5% of your battery before posting stats and jumping to conclusions.
    And let it settle for a few cycles first.
    TweakIt, G_Mr_.... and pabitrab like this.
  4. G_Mohamed_Zauri_sakR Donut Jan 2, 2017
    G_Mohamed_Zauri_sakR, Jan 2, 2017 :
    Last week i had the same issue for 4 days while I'm on Marshmallow, and did the following procedure and it worked well.
    Wait till it Drain to 0% and make a full charge.
    Do this for few times and the phone will return to normal condition.
  5. mstoecke Froyo Jan 2, 2017
    mstoecke, Jan 2, 2017 :
    You should NEVER drain your battery to 0%! That's a one way ticket to powerbank city.
  6. cwhp Gingerbread Jan 2, 2017
    cwhp, Jan 2, 2017 :
    I have the same case, as advised in community participant, I have just tried to wipe the system cache, it seems work to me as I have just tried my handset after full charge, the 1st % usage can be 7-8 mins SOT and the 2nd % can last for 5 mins, I am trying the 3rd % now.
    Before wiping cache, less than 2 mins SOT kills 1% battery. I hope this work for you, pls try it.
  7. Vivek transzakle Gupta Eclair Jan 2, 2017
    and what is the solution for battery saver where when turned on it becomes like in the screenshot number 4
  8. anilchelli Gingerbread Jan 2, 2017
    anilchelli, Jan 2, 2017 :
    :joycat::tearsofjoy:
  9. Sairam1@ Honeycomb Jan 2, 2017
    Sairam1@, Jan 2, 2017 :
    how to take screenshots on the phone after Android 7 update,and where is the home option in settings to change launchers.
  10. flexwong Cupcake Jan 2, 2017
    flexwong, Jan 2, 2017 :
    I'm also having a battery drain issue after the Android N update. My phone went from 80% to 54% overnight. Battery stats are here:
    http://imgur.com/a/Unkag
    I've done the cache clears and rebooting the phone as well.
    admagnificat and bry_tech like this.
  11. G_Alec_Chappell_XqCj Eclair Jan 2, 2017
  12. Kiran.a.joseph Jelly Bean Jan 2, 2017
    Kiran.a.joseph, Jan 2, 2017 :
    Did u try enabling the enhanced doze mode.
    Also please try the app auto-launch to restrict the unwanted apps from launching in the background automatically.
    These features might be available only in OOS 4.0
  13. Coolzfaisal25 Gingerbread Jan 4, 2017
    Coolzfaisal25, Jan 4, 2017 :
    Nothing seems to be working. Battery draining hard . I believe many who claim better battery life are on ext4 and somehow formatting to f2fs has deteriorated the battrry life for me
    wickedt2 and badal4u like this.
  14. Tonybarnaby Ice Cream Sandwich Jan 4, 2017
  15. Coolzfaisal25 Gingerbread Jan 5, 2017
    Coolzfaisal25, Jan 5, 2017 :
    Already done for the umpteenth time !!! Brother. 3 times factory reset.
  16. Linus Seiffert Donut Jan 5, 2017
    Linus Seiffert, Jan 5, 2017 :
    volume down and power button
  17. Vivek transzakle Gupta Eclair Jan 5, 2017
    wickedt2 likes this.
  18. yuvanathan Froyo Jan 5, 2017
    yuvanathan, Jan 5, 2017 :
    Night time when the phone kept idle I am getting good battery backup than OOS 3 (M) after upgrading to OOS 4 (N) with factory reset and all apps are freshly installed. Only 5% reduces now, previously it was around 10%+.
    But my battery drains fast when I am on mobile data 3g/4g. When I check battery stats Android system and Google play services consumes heavy battery also more keep awake and more mobile radio active time.
    I tried clearing cache and Uninstall new version for Google play services but still having the heavy battery drain problem.
  19. amsadri Cupcake Jan 5, 2017
    amsadri, Jan 5, 2017 :
    I have encountered the same problem after the upgrade. Battery drains strangely.
  20. steveone6 Eclair Jan 5, 2017
