My oneplus 3 has better white balance than my pro 9 via OnePlus 9 Pro
  1. Ceroes
    Donut Apr 25, 2021
    Ceroes , via OnePlus 9 Pro , Apr 25, 2021 :
    Seriously I always have to go into pro mode to make sure the white balance is properly set. I literally use my oneplus 3 still since it was my phone before this and it doesn't have this huge issue with white balance.
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 26, 2021
  3. jaivaghela
    Ice Cream Sandwich Apr 26, 2021
    dinamoski likes this.
  4. dinamoski
    Honeycomb Apr 26, 2021
    dinamoski , via OnePlus 9 Pro , Apr 26, 2021 :
    Is that before or after the 11.2.4.4 update?
    Apparently that fixes some white balance issues.
    I did notice on one occasion there was slightly too much white balance and then sometimes the photos came out a bit dark.
    But generally not too bad.
  5. jaivaghela
    jaivaghela , via OnePlus 9 Pro , Apr 26, 2021 :
    Haha I wouldn't know about before the update as when I got the phone I had an immediate update to the latest version. Hopefully the new update has fixed it for you.
  6. dinamoski
    You can check what version you're on in the settings.
  7. Ceroes
    Donut Apr 26, 2021
    Ceroes , via OnePlus 9 Pro , Apr 26, 2021 :
    I didn't notice it at first either when I got the phone. Then I noticed my walls aren't showing up correctly.
  8. Ceroes
    Donut Apr 26, 2021
    These is from the oneplus 9 Pro.
    Standard photo mode too cool this is not realistic to my environment and walls.
    Pro mode where I edit the white balance to be closer to reality. set to 3360k and -.67ev for a more accurate picture.
    G_plusone likes this.
  9. Ceroes
    Donut Apr 26, 2021
    Ceroes , via OnePlus 3 , Apr 26, 2021 :
    My trusty OnePlus 3.
    Normal photo mode colors are a little bit cooler than they should be. But are somewhat accurate.
    Pro mode. White balance has been corrected to better reflect actual colors in the room.
  10. Ceroes
    Donut Apr 26, 2021
    I would but I'm not taki g the effort to lower my resolution quality just to post the pictures. They need to up the file limit.
    They also need someone who speaks English as their first language to look over their questions, and if they already have someone who does fire them because things don't even make sense on that bug report.
    said:
    example
    "Was this a problem in previous software versions?"
    answers available:
    "no application or don't know"
    "yes this is a regression"
    "no I think it never worked before" said:
    Answering yes to this question actually means saying it never worked before yet their answer of yes apparently is in regards to it having had worked before... Their answer of no is a never worked before even though no should be it's a new issue. no application or don't know at least is clear but could be better worded as not applicable / unsure. They clearly need to rework their reports. what if yes is actually the true yes but it's incorrectly labeled we don't know... this is ridiculous. I love the hardware and what oneplus normally does but they have had how long to solve something as simple as that for their english speaking consumers...
  11. G_plusone
    Nougat Apr 27, 2021
    G_plusone , Apr 27, 2021 :
    Oneplus three still rocks. Nice
  12. Ceroes
    Donut Apr 28, 2021
    Ceroes , via OnePlus 9 Pro , Apr 28, 2021 :
    White balance set to auto.
    White balance manually corrected.
    The difference is ridiculous... Ones a cool blue purple which is incorrect and ones a correct pinkish purple.
