4
My OnePlus 5 gives an electric shock!!!
  1. daMorphine
    Honeycomb Aug 15, 2017
    G_mr._PieRacy_KSWB likes this.
  2. bhargav431
    Donut Aug 15, 2017
  3. G_mr._PieRacy_KSWB
    Gingerbread Aug 15, 2017
    G_mr._PieRacy_KSWB , Aug 15, 2017 :
    done that same problem i just went to the neighborhood to see if there is my home's electricity issue but the problem is same
    bhargav431 likes this.
  4. G_mr._PieRacy_KSWB
    manuel19 likes this.
  5. daMorphine
  6. bhargav431
    Donut Aug 15, 2017
    bhargav431 , Aug 15, 2017 :
    Better change the cable and check. My iPhone use to be same then later I moved to OP5.
  7. waldwolf
    Ice Cream Sandwich Aug 15, 2017
    waldwolf , Aug 15, 2017 :
    Most likely it was a static-electricity discharge.
    More importantly, repeated static discharges (usually high-voltage/low amperage) could damage the phones internal components.
    Suggest you talk with Oneplus Support and have your problem/complaint registered.
    _________
    G_mr._PieRacy_KSWB: Your new nick-name is now officially "Hot Lips". :p
  8. egorian
    egorian , Aug 15, 2017 :
    Don't deny that you wanted to Dash Charge yourself instead of getting some quality sleep.
  9. Freddy_Verschueren
    Froyo Aug 15, 2017
    Freddy_Verschueren , Aug 15, 2017 :
    I don't know where you live, but my charger has no earthcontact on it. So turning or checking earthing has no use.. [e]1f60f[/e]
    lostLambda likes this.
  10. G_mr._PieRacy_KSWB
    I live near USA it is near 13359 km from my east
  11. G_mr._PieRacy_KSWB
    This nick name is better than my last one
    lmao
  12. Freddy_Verschueren
    Froyo Aug 15, 2017
    I use the carbon bumper case. So I'm insolated.. Problem solved.. My phone works perfectly here in Belgium..
    Nikkhil and G_mr._PieRacy_KSWB like this.
  13. Horsault
    Marshmallow Moderator Aug 15, 2017
  14. DE ROCK
    Cupcake Aug 15, 2017
    DE ROCK , Aug 15, 2017 :
    I had the same problem as you are describing! It happened about a week ago.
  15. G_mr._PieRacy_KSWB
  16. G_mr._PieRacy_KSWB
    you know carbon is a very good conductor of electricity
  17. G_mr._PieRacy_KSWB
    is it happend later after that
  18. DE ROCK
    I havent really tried it again because it was quite painful
    #38
  19. G_mr._PieRacy_KSWB
    I am experiencing a sort of Nomophobia
    #39
  20. mark555055o
    mark555055o , Aug 15, 2017 :
    phew i'm glad it's not just me... every time i put my phone in my mouth weird things start happening...
    #40
