4
My OnePlus 5 gives an electric shock!!!
  1. G_mr._PieRacy_KSWB
    Gingerbread Aug 16, 2017
    #61
  2. JoeyBimmel
    Eclair Aug 16, 2017
    JoeyBimmel , Aug 16, 2017 :
    can you indicate what which of these you have
    #62
    Praty_28 and G_mr._PieRacy_KSWB like this.
  3. daMorphine
    Honeycomb Aug 17, 2017
    #63
    G_mr._PieRacy_KSWB likes this.
  4. daMorphine
    daMorphine , Aug 17, 2017 :
    i think that was the problem.
    #64
  5. lostLambda
    Lollipop Aug 17, 2017
    lostLambda , Aug 17, 2017 :
    I'd copulate, but not kiss it.
    #65
  6. brotherjoe
    brotherjoe , Aug 17, 2017 :
    Just fyi. All metal case phone and laptop has this electrostatic issue when charging with a two pin power adapter that doesn't have a ground pin.
    Apple products with metal case like iphone 5,6,7, all iPads and MacBooks have this problem. It is more obvious if you are charging from a 220/240v outlet.
    #66
  7. daMorphine
    you are one of those lucky people.
    #67
  8. Olixman
    Froyo Aug 17, 2017
    Olixman , Aug 17, 2017 :
    I'm surprised that the shock is so small m8..
    I use a 3pole, 32A fuse, D class at 400V to charge my phone..
    I always use rubber gloves to handle the phone while charging so i won't die..
    If possible, when i charge i carry around with me my 1cm thick rubber carpet with me so that I'm electrically isolated to the ground...
    One time i forgot my gloves and carpet at home and i did get the shock of my life.. Nearly died.. But i just had to use the phone...
    Be careful mate.. Don't end up like me.
    If possible switch to another phone manufacturer.
    (pun intended)
    #68
  9. G_mr._PieRacy_KSWB
    Gingerbread Aug 17, 2017
    #69
  10. G_mr._PieRacy_KSWB
    G_mr._PieRacy_KSWB , Aug 17, 2017 :
    APPLE HERE I COME
    #70
  11. G_mr._PieRacy_KSWB
    Actually i also don't any issue with jelly scrolling it doesn't show up
    #71
  12. MasterDomino
    Eclair Aug 17, 2017
    MasterDomino , Aug 17, 2017 :
    You don't have DC in your wall socket so u don't care about L and N cuz it switches literally 50 times a sec(eu) also inside of there u have gretz(idk the English name) bridge with some capacitors which smoothens it and makes a DC out of it, i guess its just cuz its in aluminium body which maybe is touched by smth that sends a small current
    The charger is 2 pin so it doesn't have earth pin i guess its the same in uk so no, read above.
    #72
    G_mr._PieRacy_KSWB and surya9201 like this.
  13. marcusskyfall
    Jelly Bean Aug 17, 2017
    #73
  14. surya9201
    Cupcake Aug 17, 2017
    surya9201 , Aug 17, 2017 :
    how does phase netural swap will lead to shock ?
    #74
  15. G_Gaurav_Chandela_tOUm
  16. G_Prashant_Mandaliya_FtI
    Froyo Aug 17, 2017
    #76
  17. MasterDomino
    Eclair Aug 17, 2017
    No, no, like i already said it makes no sense there's no earth pin in the charger xD
    #77
  18. sepu79
    #78
  19. sepu79
  20. G_ramu_raj_haFY
    Eclair Aug 17, 2017
    G_ramu_raj_haFY , Aug 17, 2017 :
    hi.. i just tested now. there is no shock appeared. its ok. just check your environment if it is not earthed properly or if any thing is being went wrong.
    rgds,
    raj.
    #80
