My OnePlus 6 Network Drop Issue via OnePlus 6
  1. MobinPathan
    Donut Aug 24, 2020
    MobinPathan , via OnePlus 6 , Aug 24, 2020 :
    I faced Network Drop Issue In OnePlus 6 ...I using jio network..but every minute network drops .. every minute I airplane mode on and off for Better network..but Network not work properly...please Help me To solved this problem
    Abhishek_Singh_2 likes this.
  2. ItsRavi25
    Ice Cream Sandwich Aug 24, 2020
    ItsRavi25 , via OnePlus 6T , Aug 24, 2020 :
    Try this
    Goto settings > Reset > Reset option > Reset wifi, mobile network, Bluetooth.
    Also contact your service carrier, this is not software issue.😇
    Caomhin likes this.
  3. MobinPathan
    Donut Aug 25, 2020
    MobinPathan , via OnePlus 6 , Aug 25, 2020 :
    I try This But Problem not solved .....but Thanks For help [e]1f60a[/e]
  4. Abhishek_Singh_2
    Honeycomb Aug 28, 2020
  5. joseph2779
    Cupcake Sep 28, 2020
    joseph2779 , Sep 28, 2020 :
    I have this same issue and it's still not resolved. I submitted a bug report, but have yet to get a resolution to my issue.
  6. Caomhin
    Marshmallow Sep 28, 2020
    Caomhin , via OnePlus 6T , Sep 28, 2020 :
    If you have tried the steps mentioned by @ItsRavi25 above then try the following.
    Do a Full Factory Reset
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    [e]26a0[/e]️Enable Erase Internal Storage[e]26a0[/e]️
    https://www.androidpolice.com/2020/07/18/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
    ItsRavi25 likes this.
  7. Tirirism
    Tirirism , Sep 28, 2020 :
    This seems to be a common problem for OnePlus 6 phones nowadays. My nearest phone repair center has seen 3 such cases in the past week alone. It seems one of the updates messed up with the network, probably even fried the ICs. I don't think OnePlus will accept that explanation though, since it would be their fault and customers would demand free repairs.
    Aman2601 likes this.
  8. Aman2601
    Cupcake Oct 28, 2020 at 10:32 PM
    Aman2601 , Oct 28, 2020 at 10:32 PM :
    Yes you are correct , cpu of my op6 reaches 80°C when charging and using phone or playing among us and it drops the network frequently every 20-30 mins. Normal temperature range for my phone is 35-50 after android 9 update.
  9. H1603172432237
    Cupcake Oct 29, 2020 at 4:43 AM
    H1603172432237 , Oct 29, 2020 at 4:43 AM :
    Ive got this new OnePlus6 replaced my iphone. But got disappointed with this dropped call issues. Got bang from my office for they cant call my phone since i switch to this phone. Sometimes i can't even call. And placing calls sometimes long time to connect. And i saw this issue has been there for quite some time. And no solutions until now. Phones with call problems. Pathetic...
  10. iamrj
    Gingerbread Oct 29, 2020 at 5:15 PM
    Caomhin likes this.
