My OnePlus 6T does not show MTP mode after connecting USB
  1. gdc20897
    Cupcake Sep 16, 2019
    gdc20897 , Sep 16, 2019 :
    I even went and checked developer options but it doesn't show MTP mode.
    The only ones I have are
    1. File Transfer
    2. USB Tethering
    3. MIDI
    4. PTP
    5. No data transfer
    I would like to deploy apps into my device without giving my PC, access to my device storage. (without asking permission)
    I searched some results and found out that MTP asks for permission before performing any task.
    If there is no MTP in 6T, how do I emulate similar behavior?
    Thanks for your time.!!
  2. LegolasX
    Jelly Bean Sep 16, 2019
    LegolasX , Sep 16, 2019 :
    you don't have to do anything to deploy an app, enable usb debugging rest setup up your device in Android studio.. that's all.
    i am sure you know how to push apk to it.
    if not feel free to ask.
    gdc20897 likes this.
  3. gdc20897
    Thanks for the reply sir.!
    Can you let me know how to deploy the app?
  4. LegolasX
    if you are building on Android studio then you need to click on little green play button on top right corner of the Android studio then select your device from list and click the app will build and get deployed on your device.
