My OnePlus 6t power button is not pressing and working via OnePlus 6T Mirror Black
  1. #1
  2. Praty_28
    KitKat Jul 26, 2021
    Praty_28 , Jul 26, 2021 :
    Take it to a local repair shop they'll replace power button strip for cheap.
    RAKESH GARG likes this.
  3. #3
    Praty_28 likes this.
  4. Praty_28
    KitKat Jul 26, 2021
    According to the title, you have mentioned that the power button is not pressing. I'm assuming you are not getting a clicky feeling upon pressing it anymore and the button is stuck inside the frame, am I correct?
  5. RAKESH GARG , via OnePlus 6T Mirror Black , Jul 26, 2021 :
    Yes you are right
  6. Praty_28
    KitKat Jul 26, 2021
    Okay so I am certain that it is not a software flaw and the strip under your power button is flattened which is normal and happens to most devices after prolonged use. I had replaced the strip on my OP3T and it cost me around ₹300 in a local repair shop.
