my oneplus 7 pro system update installation failed
what to do
  1. how to update the device using this type of error
    50.0%
  2. what can be done
    100.0%
Multiple votes are allowed.
  1. GopalVico
    Cupcake Jul 15, 2020
    GopalVico , Jul 15, 2020 :
    i had installed 9.5.3 on my oneplus 7 pro , but now im unable to update my phone to latest version
  2. Artemus.
    Nougat Jul 15, 2020
    Artemus. , Jul 15, 2020 :
    Manually update. Had you searched beforehand, you would've found the answer.
    R.Peter and Tobikage like this.
  3. R.Peter
    Honeycomb Jul 15, 2020
    R.Peter , Jul 15, 2020 :
    Manually update to 10.0.3 first, as @Artemus. said, then update further to 10.3.3.
    Artemus. likes this.
  4. martymcfleezy
    Donut Jul 25, 2020
    martymcfleezy , Jul 25, 2020 :
    I’m having the same issue with a new OP7 pro (GM1917) along with the OPSwitch not working. Tried the manual update and still fails. Any idea?
  5. R.Peter
    Honeycomb Jul 25, 2020
    R.Peter , Jul 25, 2020 :
    Like, share what you did so far, from which version to which version did you try to update, etc.
    Artemus. and martymcfleezy like this.
  6. martymcfleezy
    Donut Jul 25, 2020
    martymcfleezy , via OnePlus 7 Pro , Jul 25, 2020 :
    I figured it out but it was a total workaround consisting of up to an hour of time. I will make sure I send the issues to OP because it should all be as easy as plug and play.
    Artemus. and R.Peter like this.
